7 viruses from a stumble upon page
  • EquipTech
    • Jul 2010
    • 120
    Hi Digital Kaos Peeps,
    I opened a stumble upon page the other day and my computer freaked out 7 threats/virus opened and attacked my anti-virus and system configuration files...
    My Anti-virus was AVG full version... it turned off the all shields and disabled my restore points after hours of searching the web for advise and running scans and anti-malwere scans I removed most of the damage well to the best of my ability. and corrected my configuration settings
    Since this has happened my pc is running slow and lagging like a beached whale trying to through the sand.
    I have totally removed AVG and now running Avast I used the AVG removal tool so im pretty sure it was completely removed before I installed the new anti virus.
    Any help to resolve this issue will be greatly appreciated!
  • brumetw
    • Apr 2010
    • 21
    Try to install avast! Anti-virus software, i use that is very nice to protect my computer.
      run a scan with malwarebytes, different avs pick up different things your pooter could be still infected, also run ccleaner.
      • EquipTech
        • Jul 2010
        • 120
        I am running avast now... Agreed it works very well Thanks for your response
        • EquipTech
          • Jul 2010
          • 120
          Hi there, I have run Malwarebytes' Anti-Malware, HijackThis and CCleaner. Picked up a few things and cleared them but still no joy... thanks for your help
          • ezzda1
            • 172
            try superantispyware, SUPERAntiSpyware.com | Remove Malware | Remove Spyware - AntiMalware, AntiSpyware, AntiAdware!
            and try drweb cure it its a russian av service and is very good. Dr.Web CureIt! — ??????? ????????? ?????????! ??????? ???????, ?????? ?????????? ?????????!
            if they dont work theres combofix A guide and tutorial on using ComboFix scroll down to the blue bleepingcomputer.com link to download it. BE VERY CAREFUL with combofix.
            there's also something called housecall from trend micro, its probably best to use that last
            Trend Micro HouseCall - Free Online Virus and Spyware Scan - Trend Micro UK
            I use avast free and threatfire ThreatFire AntiVirus - Behavioral Virus and Spyware Protection without problems,
            maybe they will find something malwarebytes and hijack this missed.
            • Elric
              V.I.P. soft lad
              • 853
              if all else fails back up what you need (in safe mode if poss)
              then reformat the hdd
              • sanscorp
                • Apr 2010
                • 75
                Try AVG, this includes a lot of mal- and adware.
                AVG is a free virusscanner, currently #1 in the world.
                Avast is good but slower (takes more resources)
                Also install Ad-Aware (also free) as AVG isn't enough of protection alone.
                • stevj
                  • Apr 2010
                  • 16
                  Another utility that's really good is Autoruns. It lets you see and disable (or remove) programs that start at boot, and has many other uses as well. If those threats and viruses you caught have left behind monitors/keyloggers/etc that run at boot, this program should find them for you and let you turn them off.
                  Check it out at Autoruns for Windows
                  Another program that helps me clean up after "accidents" is a program called Registry Crawler.
                  Trial version available at Download Registry Crawler, Registry Crawler 4.5.0.4 Download
                  Good luck.
                  Steve
                  • kreller
                    • Aug 2010
                    • 49
                    Advanced systemcare are also a good tool, and it's free.
                    • staind
                      • Apr 2010
                      • 20
                      i am use a nod32 antivirus
                      is good
                      • staind
                        • Apr 2010
                        • 20
                        but you have the activation code for each 6 month :-0
                        • tooseyman
                          • 26
                          I always keep a system image on a removable hard drive, then if the worst happens and I need to reformat the main hard drive I can just load everything back on in one go. Saves hours of work!
                          • EquipTech
                            • Jul 2010
                            • 120
                            Hey peeps, thanks for all the help here! ezzda1 I have run SUPERAntiSpyware.com | Remove Malware | Remove Spyware - AntiMalware, AntiSpyware, AntiAdware! and Dr.Web CureIt! — ??????? ????????? ?????????! ??????? ???????, ?????? ?????????? ?????????! After the scans the pc seems to be back to normal. Cheers for the advice... much appreciated!
