laptop HDD adapter
  • filthy1980
    • May 2010
    • 19
    laptop HDD adapter
    hi folks,
    wonder if someone could help,
    a friends given me a laptop to fix, basically it won't power up, checked the power supply that seems to be fine,
    tried a different PS that that won't charge the battery or power the laptop either.
    Have tried removing the memory for 30 seconds and a couple of other tricks but still nothing no sound of anything kicking in either.
    I'm thinking the laptop is a gonner and not worth economical repair so i'm just trying to recover the data from the hard drive.
    The laptop is a Dell inspiron 510m, HDD is a WD 400 Scorpio Enhanced IDE Hard drive (s/n: wxe305283491), I've got a IDE/Sata adaptor and have brought a 2.5-inch to 3.5-inch IDE Hard Drive Cable Adapter, but this doesn't fit the hard drive,
    the HDD is a 44 pin female connection, but male pins on the adapter is a 40 pin, and the pins are too thick to match up to the HDD.
    I've had a shop around and can't find the appropriate adapter,
    could anyone point me in the right direction?
    any help appreciated
    cheers
  • gaz925
    • Jul 2010
    try looking on ebay
    • filthy1980
      • May 2010
      • 19
      Originally posted by gaz925
      try looking on ebay
      thanks mate )
      • N3lson
        • 18
        I normally buy them on Ebay for about ?1.60, but delivery can be a bit slow at times. If you're in a hurry you can get one from Maplins for ?6:
        IDE to 2.5 Laptop IDE Cable : ATA Floppy Cables : Maplin
        • doughboy
          I have one of those.. It does work, but it didn't really like a sata boot.
          I went down another route and bought a hard drive caddy for my old thinkpad t23. Allows the dvd/floppy slot to take a 2nd hd instead
          • gtpilot
            • Feb 2010
            • 36
            This is definately the best product to have and gives flexibility to use with any hard drive drivewire - universal hard drive adapter
            Also acronis relabled software is bundled for free.
            • sat0finder
              • Feb 2010
              • 4
              Can you post a pic of Hdd?
              • Tyagiji
                • 5
                I know it's Very hard to find that
                • gox
                  Originally posted by filthy1980
                  hi folks,
                  Have you tried powering it on with the battery removed? It has been known before that a duff battery can prevent a Dell from powering up.
