I updated my drivers, then re booted and now computer starts and goes straight to sleep mode, I safe mode started it and done a virus chck and now it does the same when I start can anyone help pleasee
computer starts then goes to sleepmode help please
Go to control panel and click power option and change more time on sleep mode.
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
did you have a system restore set? you may be able to restore to an earlier date. check in start>programs> accessories> system tools> system restore
what do you mean "you tried the power options and this doesn't have that option"? If you have xp installed then you have this option unless you have screwed up the system with "modifications"
you can change the power options in the "control panel", "power options", select the "power schemes" tab and then just change the monitor, hard disk and system standby to "never".
The Falkirk Wheel.sigpic The only rotating boat lift of its kind in the worldComment
I had a problem similiar to this..
Whenever i boot my pc, it started up then dropped intp hibernation/sleep mode..
I changed memory, fiddled with xp control panal but in the end, it was a virus. Cant recall which varaint but i scanned with a usb key version of anti-virus, then run a malware check... voila
Might help you buddy boy
good luckComment
Do what Dreamer said, otherwise you may have to use Malware remover tool your system may be attached by the aliens, and hit the thanks button as you go mate!
sorry mate was on my phone, basically its due to installin new drivers using a software called driver genius Pro, I installed the new drivers which some didnt work therefore messing everything up and now its all bad quality for films etc, what would be best solution? I found system restore which worked jjust everything on it is crap, its in that mode where everything is enlargedComment
you are an absolute legend mate dont know how to thank u, sorted evertyhing outdid you have a system restore set? you may be able to restore to an earlier date. check in start>programs> accessories> system tools> system restore
you can change the power options in the "control panel", "power options", select the "power schemes" tab and then just change the monitor, hard disk and system standby to "never".Comment
