blue screen of death :(
  • barrowmanandrew
    • 3427
    #46
    Originally posted by pipeman1
    you can fix it without loosing anything!!!!!!!!!!!!!
    come on then , spill the beans
    • cunny
      • 4915
      #47
      Can you list all your componants.
      Number of drives, both hard drives and optical.
      RAM configuration and Make
      GFX card
      PSU Wattage
      Motherboard Model Number.
      As i have stated. The only true way to get to the bottom of these is to strip the pc down to bare bones and see if still happens, run memtest 4.0 (from hirrens boot disc) over night to fully test RAM.
      This could easily be something from a bad sata lead to faulty motherboard.
      • barrowmanandrew
        • 3427
        #48
        not an easy fix then .
        i'll strip it down on me next day off...
        • Shady
          Shite Link King
          • Dec 2010
          • 6404
          #49
          Originally posted by donkeyboy
          can i ask how you no such a thing
          go to microsoft site via messenger etc, the find the page you are after. in a seperate window, go to the site you went to and compare the differences.
          no pop up on proper ms site, and other site is a different shade of blue
          • RedSpider
            • 2448
            #50
            what is it with you? you've made 2 posts alluding to an easy fix but revealed nothing in the way of help. we'ld all like to know this great wisdom you purport to have so spill it or shush
            Syntax Error : Integer Out Of Range
            Hooray For Tits & Fannies
            • donkeyboy
              • 410
              #51
              @ shadyback
              Will do tonight
              • barrowmanandrew
                • 3427
                #52
                an update on my situation.
                i stripped down pc.
                inside was filthy especially the heat sink round the processer.
                i bought a tin of compressed air and gave it a thorough clean out (thanks to cunny for that suggestion)
                i took out ram strips and cleaned connections then reseated them.
                finally did a fresh instal of win 7.
                pc is running much quieter and no blue screen or freezing as yet.....
                fingers crossed...
