Free Huawei Modem Unlocking and Support Thread
  • yosarian
    • Sep 2009
    • 75
    #91
    Originally posted by Jim.Mahoney
    These can only be unlock via cable, provided the USB port on the device hasn't been disabled.
    Unlock phone, modem, data card with DC-unlocker software is probably the quickest route. I can do here for free but I'm in South Africa!!
    the prot has not been disabled, it is possible to unlock withowt the dongle ?
    BR
    • Jim.Mahoney
      • Feb 2010
      • 4249
      #92
      BR
      With DC-Unlocker:
      1. Download and run Client Software
      2. Check that it can 'see' the modem
      3. Buy enough credits to unlock
      That's it!
      • yosarian
        • Sep 2009
        • 75
        #93
        With DC-Unlocker:
        That's it!
        Thank you, and now is another q, how to use it on another company than the originaly wher was locked ?
        • Jim.Mahoney
          • Feb 2010
          • 4249
          #94
          Change the SIM !!
          • yosarian
            • Sep 2009
            • 75
            #95
            Change the SIM !!
            I did already, recognize the network but is not conectet to the internet ? i have no access to see the number to be dialed, i was only able to cange the apn, and password
            Thank you !
            • Jim.Mahoney
              • Feb 2010
              • 4249
              #96
              The number dialled is almost always *99# and you can set this in Windows Dial-Up Networking.
              Try here: http://www.dc-files.com/files/huawei/routers/B970/
              You may need to flash generic firmware if everything is locked!!
              • arex59
                #97
                I can't to find free Huawei Modem Unlocker for K3765, please assist me ..thank you.
                • Jim.Mahoney
                  • Feb 2010
                  • 4249
                  #98
                  Just calculate the code it should work!
                  • jackhulk
                    • Apr 2012
                    • 7
                    #99
                    Hello
                    Trying to use the SBC Code Calculator v1.30 to unlock my Huawei E367U. Left it on autoselect first of all and seemed to work as it read the device and calculated codes, however unlock code didn't work (9 tries left).
                    Round 2 - This time instead of autoselect I tried to select my model but E367U isn't on the list. Is this model supported please? Is there a post V1.30 version of this program
                    • Jim.Mahoney
                      • Feb 2010
                      • 4249
                      #100
                      Originally posted by jackhulk
                      Hello
                      These have a new algorithm and can't be calculated!
                      However:
                      This is supposed to unlock both Huawei E367 and E353.
                      I don't have either modem here to test.
                      Modems also theoretically supported:
                      E367u-1_1G
                      E367u-2_1G
                      E367u-6_1G
                      E367u-8_RFMD
                      E367u-8_AVAGO
                      E353u-1_1G
                      E353u-2_1G
                      E353u-6_1G
                      It is important that you use backup NVitems just in case. I'm told that should you have only 2G service after the unlock the NVitems need to be restored manually to correct the issue.
                      You will also need the firmware and you'll find that here: firmware.zip download - 2shared
                      Caveat: I have never used this software to unlock either model. It unlocks by a firmware patch and not by code! Therefore I can not support this software nor be held responsible for any damaged the software or your incorrect use of the software may cause!
                      The software comes from a well know writer of GSM tools. I heard of others using it with 100% success. The choice is yours!
                      Please post your results to help others!!
                      • jackhulk
                        • Apr 2012
                        • 7
                        #101
                        Great stuff, thanks Jim.Mahoney! I didn't fancy taking a chance and mess things up so I return this dongle to shop and purchased a pre-unlocked one from eBay.
                        Problem I have now is that while can connect via Mobile Partner using GiffGaff sim, app clearly shows I'm connected but when I try to access a web browser, no pages will load, acting as if I'm not connected?
                        UPDATE: Issue resolved. PC was connected to router which was on, but no active DSL line. Switched this off and now I can connect via dongle. No idea why non active Ethernet would interfere thought. Strange.
                        • jackhulk
                          • Apr 2012
                          • 7
                          #102
                          Anyone know how I can stop the 3 software trying to install itself each and everytime I insert the dongle please? I can see the files within file explorer but they are protected.
                          • wqertypoiuy
                            • Apr 2012
                            my hero
                            Jim.Mahoney the lifesaver!
                            • Jim.Mahoney
                              • Feb 2010
                              • 4249
                              #104
                              The quick and easy way is to turn 'autorun' off within Windows. It varies between Windows XP, Vista & 7 so call up Windows help and search on Autorun for the method.
                              There are other methods be these depend on your computer skills...
                              • jackhulk
                                • Apr 2012
                                • 7
                                #105
                                Thanks but I'll like to keep autorun activate for everything else.
                                Most interested in how to either rename autorun.inf. or delete the autorun files but they are all protected. Do you know how I can unprotected these in order to delete them? I'm using Windows XP.
