You can't as they are in .ISO format on the CD emulation on the device!
Try this:
If the version on your PC does not match the dashboard on the device (even if its newer) it will always try to re-install.
To stop this look at the file called SysConfig file on the modem (CD-ROM emulation) and search for the section towards the end of this file highlighted below:
Look for this section:
[EHIDS_PRODUCT_VERSION]
COMMENT=
RUN_INSTALL_APP=YES
RUN_CLIENT_APP=YES
L_REG_PATH=SOFTWARE\Huawei technologies\Mobile Partner
APP_FILE_NAME=Mobile Partner.exe
SETUP_NAME=setup.exe
APP_INSTALL_PATH=Mobile Partner
VALUE=16.001.06.01.500
The line in your file may vary from this of course!
The file that you need to edit on your PC can be found in \Program Files\Mobile Partner\ and it is also called SysConfig and it must have exact match for this line!
If it doesn't edit it to read exactly the same!
You may need to change the read attributes from "Read Only" for this file before you edit it!
You can also edit the line RUN_INSTALL_APP=YES to RUN_INSTALL_APP=NO instead. However, if you do this any new modem will not auto-install unless you manually remove Mobile Partner first as you will probably have forgotten that you've edit this file by the time you try to install a new modem!!
