Huwei Modem Unlockers
  • paul acidspoof carissimo
    • Apr 2012
    • 9
    These softwares are self explanatory, connect modem auto calc unlock code , then unlock, worked on my e173, oh and one more thing these didnt work for me on windows 7 ,they keept giving a dotnet frame work error, works perfectly on xp.
    LINK
    password : acidspoof
  • singleperson
    • 397
    Hi mate,
    Please help me with Hauwei 353s-1:
    Found modem : E353S-1
    Model : Huawei E353
    IMEI : 356791040431706
    Serial NR. : D3C5TA11A3100677
    Firmware : 21.137.01.00.556
    Compile date / time : Oct 9 2011 17:03:04
    Dashboard version : UTPS21.005.20.02.556_MAC21.005.20.02.556
    Chipset : Qualcomm MSM6290
    Voice feature : not supported in current firmware
    SIM Lock status : Locked (CardLock)
    Wrong codes entered : 0 (unlock attempts left : 10)
    Thank you very much.
    Technical Support: Cummins + CAT + Perkins + Volvo Truck + Volvo Penta + Detroil Diesel + Isuzu + Scania, etc...
    Support Remote Installation and diagnostics
    • Jim.Mahoney
      • Feb 2010
      • 4249
      Warning the second program has been reported to contain a trojan virus. Not tested by me but be aware!!
      • Jim.Mahoney
        • Feb 2010
        • 4249
        Originally posted by singleperson
        Hi mate,
        Model : Huawei E353
        Uses a new algorithm and STILL can't be calculated!
          • Apr 2012
          • 9
          I have avira installed , I detect nothing.
          • newfutil
            • Jun 2011
            will this do the zte versions too ?
            • Jim.Mahoney
              • Feb 2010
              • 4249
              Here's a clue, it's called Huawei Modem Unlocker...
              • Jim.Mahoney
                • Feb 2010
                • 4249
                Try it with NOD32...
                  • Apr 2012
                  • 9
                  from what I know avira has the highest detection , I detect viruses and malware when all other av's claim my system is clean including nod32, I've used nod32 kaspersky avg webroot bitdefender rising panda mse , nod32 is probably detecting a false positive, I'll stick with avira
                  • Jim.Mahoney
                    • Feb 2010
                    • 4249
                    Well I know of few professionals using Avira, I assume its a home anti-virus package...
                    I know someone who loaded the Bojs unlocker on his system and it hooked itself in and refused to stop loading each time the system booted. Took him ages to get it removed completely!
                    So, the choice is yours!!
                    Plus of course there has been a perfectly good unlocking program on the forum for ages!
                      • Apr 2012
                      • 9
                      okay , good. now I have a problem , I unlocked my e173 and my friends e173 but they cant be detected on his mac , same thing on my pc , I re-installed windows and the modems are not being detected I have to manually install the drivers.......errr......I might have played around with the "disable cd " function on the unlocker on both modems out of curiosity , flashing a different dashboard version didn't help, any suggestions ?
                      • Jim.Mahoney
                        • Feb 2010
                        • 4249
                        Neither of these programs would I trust to do exactly what they say!
                        Attached is MDMA which is a tool for Data Cards.
                        You must disable any other dashboard software before running!
                        It also has command line switches and the one you need is /u2diag:<x> switch where <x> is your selection and 255 enables both CDROM (emulation) and SD Card.
                        See the readme file this should explain everything!
                          • Apr 2012
                          • 9
                          alright thanks ,trying it now.
                            • Apr 2012
                            • 9
                            I must be doing something wrong, this is the syntax I use
                             mdma.exe /u2diag:255 /port:com 6
                            but I keep getting " warning : incorrect value for ^U2DIAG sent "
                            • Jim.Mahoney
                              • Feb 2010
                              • 4249
                              Put the port command first:
                              MDMA /port:com6 /u2diag:255
                              if no joy try:
                              MDMA /port:com6 /u2diag:1
