inserting mep into blackberry curve 9300
  • monty5
    • 34
    hi guys lookin for some help here i have a bb 9300 but when i try to put the dash in for the mep number it wont let me?????????????????????????
  • Canker_Canison
    • May 2010
    • 3905
    What dash?
    If you have been given a MEP2 code to unlock the phone you just have to insert a different network SIM & turn on.
    The phone will ask you if you want to unlock the phone. Then you just type the code in.
    If you are trying to get your MEP code so you can generate an unlock code, there are easier ways.
    There's a MEP reader somewhere in the PDA/Mobile section attached to a closed Blackberry unlocking thread. You can still download the program.
    Or you can post your IMEI & PRD code & I'll give you the MEP2 code.
    Canker
    [COLOR=Green]
    • monty5
      • 34
      ive got an mep code from the code generator from DK but its four numbers then a dash then another three numbers but the fone wont let me put the dash in ?????? probably me just being thick but followed info on generator?? any ideas
      • Canker_Canison
        • May 2010
        • 3905
        The MEP reader only reads a protection code from the phone. That MEP code is used along with the IMEI to generate the unlock codes.
        The MEP code you have is not the unlock code.
        Post your IMEI & either the MEP code you have or the PRD from the sticker under the battery. I'll get you the unlock codes.
        Canker
        [COLOR=Green]
        • monty5
          • 34
          imei 356319040966438
          mep: mep-09292-006
          cheers again.
          • Jim.Mahoney
            • Feb 2010
            • 4249
            mep: mep-09292-006
            cheers again.
            IMEI : 356319040966438
            MEP : MEP_09292_006
            Calculating..
            MEP1 (SIM) : 71 45 56 02 09 53 35 53
            MEP2 (NETWORK) : 84 50 51 89 34 40 03 86
            MEP3 (NETWORK SUBSET) : 52 59 14 28 01 83 58 46
            MEP4 (SERVICE PROVIDER) : 41 81 37 32 82 93 71 73
            MEP5 (CORPORATE) : 90 39 32 18 76 79 54 76
            Spaces in codes are just for clarity and should not be entered!
            • monty5
              • 34
              thanks guys dont know wot id do without this site.
              thanks again
              • willldernes
                • Oct 2012
                Hello Everyone,
                I have a similar problem. I have a BB 9630 which was formerly used with Verizon and would like to unlock the phone to use an AT&T sim. I found out the mep code which is in the format of xxxxx-xxx. The code doesn't work and I think it may be because of the dash in the code which I can't figure out how to type. I've tried all 8 digits and also tried only the first 5 digits with no success. Any ideas guys? Thanks.
                • Jim.Mahoney
                  • Feb 2010
                  • 4249
                  Originally posted by willldernes
                  Hello Everyone,
                  The MEP code and IMEI are used in conjunction with each other to generate the unlock code. The unlock code will be either 8 or 16 digits long! The MEP is NOT the unlock code!!
                  • Josman21
                    • Oct 2012
                    I was wondering if anyone could help me unlock my blackberry 9300, i dont understand how you obtian the unlock code using the mep and imei code? Help would be very much appriciated
                    • pupxo
                      • Nov 2012
                      hiiiiii please help
                      imei number - 356319041965033
                      PRD - 33259 - 002
                      i would love you to generate my code for me!
                      • pupxo
                        • Nov 2012
                        @ canker cansion! please help me! i posted my imei and prd numbers!
                        • smirnoff_rules
                          • 8603
                          http://www.digital-kaos.co.uk/forums...g-tool-248342/ do it yourself here
                          • thecoller
                            • Jan 2013
                            thanks....................
                            • Ahsan asif
                              • Feb 2013
                              Blackberry 9300.mep code
                              Hi there.....
                              Please I need help.....!!!
                              I need the MEP code for the blackberry 9300 ?
                              IMEI :355894040812411
                              PRD : 29973001
