3 usb wifi dongle FREE pay and go :)
the dongle should work outside the uk as it uses mobile phone providers but you will have change some settings and may be a differant sim it will also probally be quite expensive every time you use it to connect to the net.sigpicComment
You probably could use the o2 sim abroad if you active roaming, but i should imagine the expence to be quite high. It is worth noting that the free internet with an iPhone sim does not apply whilst roaming.XBMC/KODI DeveloperComment
follow the link it will give you info on using your dongle abroad as to charges etc.
Will I be able to use my mobile broadband account abroad? - Mobile Broadband HelpsigpicComment
sigpicComment
when you take a uk sim abroad it usually connects with a provider that your uk provider will use so that you can make calls in effect you are using 2 networks.
if you get a movistar sim when you are in spain you will only use their network what the cost will be to use it for broadband and if you can you will have to find out but it should be cheaper as you will not be paying roaming charges.sigpicComment
