streaming movies
  • blueflash234
    • Mar 2009
    • 904
    streaming movies
    is it possible to stream movies from the pc to et 9200?
    Yes it is possible just create a network mount on your box and PC and share from there
    • flyingpig
      • Aug 2009
      • 930
      Yes, and it is very easy to setup. If you are using a linux os, you can make your pc into a DLNA device, and the ET9000 will pick it up and play media direct from it.
      • blueflash234
        • Mar 2009
        • 904
        how do you make your computer a dlna device and how does the box pick it up?
        • flyingpig
          • Aug 2009
          • 930
          Not sure how to do it on Windows, but on Ubunti there is software that you install, and it makes your pc broadcast on the dlna network.
            Unsure what Image you have on your 9200 so, But it should have an option for you to create a Cifs mount folder on your PC/Laptop etc.. which will allow your 9200 to see this on your network. Anything you want to watch put in that folder and away you go
            • blueflash234
              • Mar 2009
              • 904
              the image is xtrend v4
