Yes, and it is very easy to setup. If you are using a linux os, you can make your pc into a DLNA device, and the ET9000 will pick it up and play media direct from it.
how do you make your computer a dlna device and how does the box pick it up?
Unsure what Image you have on your 9200 so, But it should have an option for you to create a Cifs mount folder on your PC/Laptop etc.. which will allow your 9200 to see this on your network. Anything you want to watch put in that folder and away you go
