Problem with cas 3 interface.
  • wooper
    • 460
    Hello.
    I knew this was never going to be easy.
    I have loaded the cas studio 8.6b to computer.
    It's saying connect the device in your usb port.
    I have a usb to serial cable, which works as have flashed Kryptview box, then a NULL modem cable connected to this, then a gender changer to connect to interface.
    But nothing. Do I need a different cable to Null modem one??
    Help!!!
  • benny/9
    • 1964
    Originally posted by wooper
    Hello.
    Help!!!
    hi wooper
    for the cas 3 you use a usb cable the same as you use for your printer
    you dont use the 9 pin port on the programmer for the diablo cam
    Please Read Carefully!
    • wooper
      • 460
      Thanks again for your promt reply benny.
      dont have a printer at home. Would you be good enough to give the exact spec cable so I can buy one.
      • wooper
        • 460
        Benny, you ARE the man.
        A thousand thanks.
        Mrs heard me grumbling. Turns out we have an old printer in the garage. Cable works a treat.
        I was sat here for last 2 hours moaning.
        Next need to load 1.49.
        so will no doubt be on in a bit moaning!!!!!
        • benny/9
          • 1964
          hi wooper,
          i get all my cables from a guy at rainford
          i will pm you mate or if you have a maplin near you
          you can get them there but not as cheap.
          USB 2.0 Hi-Speed A to B Cable Lead For Printers
          • benny/9
            • 1964
            A thousand thanks.
            hi wooper,
            did'nt you say it was aready loaded with the 1.49 file when you got it?
            if it was all you need to load is the latest data file i posted.
            • wooper
              • 460
              no, it was 148.
              all scrambled.
              have just loaded 149.
              do i have to load your new data bin too????
              • benny/9
                • 1964
                no, it was 148.
                all scrambled.
                hi wooper,
                yes mate load the data file. the keys changed
                i have posted how to load it this loads very fast for you
                • wooper
                  • 460
                  Benny,
                  i have your data bin on the bottom left, green arrow pointing left and yellow pointing right.when highligthed it says read file error or write file error on yellow arrow
                  • benny/9
                    • 1964
                    Benny,
                    have you got the data bib out of the folder before for loading
                    when you click connect at the top of the loader and wait
                    then the cam will connect and both arrows should be green
                    • wooper
                      • 460
                      Thanks again Benny.
                      could not have done it without you.
                      Funny thing is, its all done in minutes, but then you dont know what you dont know!!!!
                      Turned on TV just before going to work this morning and all film and footy is back on.
                      Was dreaming about bloomin cables and null modems!
                      Next time should have it done in 2 minutes, not 3 hours!!!!
                      • benny/9
                        • 1964
                        Thanks again Benny.
                        it gets easier mate the more you load the cam, then everything
                        will take you minutes, and when your dish is sorted you will realy
                        get a lot to watch
                        • .: JaCkPoT :.
                          Retired Sat TV Addict
                          • 5607
                          But things can disappear very quickly....
                          ___________________
                          In the good old days, I had
                          DM800s HD
                          Openbox S10
                          TM500
                          DM500s
                          90cm FortecStar dish
                          Maxx 110cm Dish
                          Technomate 2300 Motors
