home plugs
  • markedz
    • 185
    home plugs
    do these have to be plugged into wall sockets or can they be used in extensions
    also any ideas on the best ones for use with a blade 7000
  • mark8393
    • 2305
    i use these 200M Powerline HomePlug Network Adaptor | eBay UK , and they work fine on extensions, or you can use develo ones on ebay they are about ?25
    • markedz
      • 185
      cheers
      cant find devolo ones on ebay
      will any be ok
      • mark8393
        • 2305
        cheers
        will any be ok
        DEVOLO HIGH SPEED HOMEPLUG KIT TWIN PACK DLAN POWERLINE | eBay UK heres some, not sure how they work on extensions
        • setfiretorain
          • Jul 2010
          • 934
          I use them that Mark posted just there, the Devolo, Really good homeplug, work as expected and really quick.
          Plug and Play really.
          '"If you can't make decisions in life, you're a bloody menace. You'd be better becoming an MP!"
          Quote from Mr Shankly, YNWA, JFT96
          Sat Boxes
          Spiderbox 7000 HD with " gift "
          Dreambox 500s.
          Dishes
          1.1 Motorised triax satellite dish single LNB.
          Sky minidish self fitted.
          • excollier
            • 187
            I read on another forum that homeplugs are really a type of radio transceiver, so it makes no difference where you plug them in as long as they are within range. A bit like a baby monitor if you like. I use Devolo myself.
            Get to the Ulster Grand Prix
            Dundrod Co. Antrim
            Every August
            Learn what fast Really is!
            NOT for the faint hearted
            or watch it on BBC NI HD the following week
            (What is football all about?)
            • cactikid
              • 12017
              i think i heard if the extension has surge protection you may have problems,they take the signals through the mains but to work need to be on the same circuit/ring
              • markedz
                • 185
                these are 85 Mbps
                wud i best to get 200 mbps
                or isnt there really any diffrance
                • mark8393
                  • 2305
                  these are 85 Mbps
                  85 will work fine, i got the 200 ones i use cheap, a guy i know did not want them
                  • setfiretorain
                    • Jul 2010
                    • 934
                    No real difference, Especially if your using them for what i think you are.
                    Regards.
                    Sat Boxes
                    Dreambox 500s.
                    Dishes
                    • plasterer
                      • 1631
                      Yes i heard the same thing ,but cant confirm this .
                      If all your downstairs sockets blow a fuse and your upstairs sockets are still working
                      This would indicate a diff circuit and these may not work
                      Can anybody confirm this ,Cheers ............Paul
                      PAUL
                      • rofak
                        • May 2011
                        hi , i think they still work. my mate got them, he's got the stb plugged in downstairs and the his computer upstairs, and they work. i mean the upstairs and the downstairs wiring are connected the one power supply box (main juction box ).
                        hope this helps.
                        • markedz
                          • 185
                          Regards.
                          i may well be
                          • cactikid
                            • 12017
                            mine are on different circuit as upstairs differers from downstairs to overcome added another lan cable and 2 other lan plugs to join works a treat
                            • paul and kay
                              • Apr 2011
                              hi all i have found orange devolo plug to work well with blade 7000s plug in and a few seconds later working great with receiver, i did try vonets bridge but that didnt work at all over distance i needed data to travel, so would recommend orange devolo high speed 85 mbps home plug , around 30 pound
