blade ip set up, help??
  • hollandish1
    • Dec 2010
    • 54
    just purchased a blade7000 satellite box, sorted out the cardshare but unsure how to keep my ip address fixed.
    my provider changes my ip every now and then and i think this may interupt my service. is there a way around this?
  • lincsat
    • 1228
    You can setup a free DynDNS account to track your IP, you would then give the dyndns address to the server.
    • Rodbouy
      • Jul 2010
      • 1320
      I take it your box has a direct connection ? if not the Router most likely keeps the same IP range no matter if the real IP changes.
      Although press menu then look down the 1st list for ip and set a static IP in your routers range.
