Not being funny it goes the same with the dreambox 800, mine came with it fully loaded, all i did was load the bouquets and cl++e, tuner set up and bobs your uncle.
And later on when you get used to the box which you will you will find alot of joy from it, ie:- plug ins, different images, streaming etc.....and the support on here is second to none.... but it's your choice.
mine both came pretty ancient firmware wise, had to update everything including bootloader anddddd get myself two new M tuners. But i did get the two DM's for free
If You Like My Post-----------PRESS THAT THANKS BUTTON
