Hey Guys
Not sure if this has been posted as im new to DK but if it has then admin please remove.
Im going to show you how to use a mobile broadband dongle on your ethernet Supported STB, (This also works for PS3 & Xbox 360)
Things You need
(1) Pc/Laptop
(2) Ethernet Cable (cat 5 or 6 )
(3) Ethernet Supported STB
Here I'm going to show you how to share your 3g internet connection with your satellite without having to buy a 3g wireless Wire-less router with the use of your pc/laptop and an Ethernet cable! Its very easy to do but a lot of people don't have a clue and go ahead and pay for the router !!!
(1) Connect your broadband dongle to your pc/laptop via usb port and click connect so you have a active connection to the internet
(2) Use the ethernet cable and connect it from your pc/laptop to your STB
(3) Now go to control panel and click " view network status and tasks" then click "view status" and then "properties"......
(4) Now you need to click the "sharing tab in the top right hand corner
(5) Now tick the box that says "allow other network users to connect through this computers internet connection" if prompted for a password enter it or contact your computers administer. After putting in the password click "ok"
Note: if a text box appears telling you that you can only share the connection when "you" are logged in just click ok.
(6) Now disconnect from the internet and reconnect, and you should be good to go with a active internet connection to your STB
Hope this helps Guys
Things You need
(1) Pc/Laptop
