blade BM7000s-05-10-11-7ex
  • markedz
    • 185
    #16
    Originally posted by vorlon2257
    make a note of them first on some paper. or you will loose them
    didnt get em when i got box,guess im stuck with older f/ware then cheers
    • zee24
      • 3342
      #17
      go to any channel and press 9991 on your remote a menu should appear and in there you will find your cline, just note everything down and your good to go.
      But you won't lose your cline when updating firmware you only lose them when you factory reset the box, but id still make a note of them just in case.
      • markedz
        • 185
        #18
        they are password protected by seller,and he aint been seen since april,so i dont no what he did as it isnt 0000
        i updated firmware in may with no probs tho,just dont wanna do it and lose em,as it will be another sub then
        • zee24
          • 3342
          #19
          you wont lose em dnt worry if you upgrade tho. The only way to overite the password is to do a factory reset but then you will deffo lose the cline n the info but i could be wrong.
          Like i said you won't lose the cline if your just doing a firmware update
          • mark8393
            • 2305
            #20
            Try 9996 mate
            • markedz
              • 185
              #21
              Originally posted by mark8393
              Try 9996 mate
              cheers wasnt that combination,how many tries to do you get,cud be any amonunt of combs
              • mayne1872
                • Oct 2011
                hi has someone got the firmware
                05-10-11 with the 9991 menu please
                • zee24
                  • 3342
                  #23
                  if you want that update its on the 1st page before this one
                  • ulrich100
                    • 29
                    #24
                    If this firmware doesn't solve my ip dropping problems, I shall be posting a video of Blade Vs sledge hammer.
                    • mupster
                      • Oct 2011
                      Hi fellas,
                      I wonder if anyone can help me...
                      Whenever I switch channels via the number pad on the remote, the box seems to lose its signal and I get a 'no video/audio' message on the screen. I then have to swtch the unit to stanby and back on for the channel to show up. It doesn't happen if I switch channels via guide or prg up/down.
                      Any ideas?
                      • irishbluestaffy
                        • 611
                        #26
                        do u have the latest software on it as i had this trouble on old software.
                        • 4sparx
                          • Oct 2011
                          #27
                          Update
                          Just downloaded the latest BM7000s firmware from 1st page BM7000s-05-10-11-7ex, have noticed it does not end with .stb just ends with 7ex, before I flash my box and it goes flash, am I rigfht in saying to rename the unzipped file so it ends with .stb then the box will recognise it?
                          I renamed the file, ending it with .stb so the box would see it, it does see the file but as soon as you try to load it, "Invalid STB file", tried renaming it ending with 7e.stb to no avail, has anybody else had this problem, the blade took tha last firmware with no hickups
                          • irishbluestaffy
                            • 611
                            #28
                            u dont need to rename it m8 just flash it as it is thats wat i did.
                            • 4sparx
                              • Oct 2011
                              #29
                              Update
                              Its not seen as a file on the memory stick although it is there cause I just put it there, wierd, will give it another go, I am in utils, download, and as soon as I select the file, it tries to read then says "Invalid STB file"
                              Just downloaded the zip file again, its writing to the blade as I write, the file must have become corupt as I unzipped first time around, box reads 100% success, excellent, thanks for the updated file with the 9991 option, great
                              • 3333
                                • Oct 2011
                                #30
