mandatory spiderbox HD patches
  • Einsvonzehn
    • Dec 2011
    • 23
    #61
    Originally posted by ramjet
    they never publish what the changes are to the patches, you just have to assume they add fixes or change the menus or whatever
    as for the softcams, they are what is left of the old types of keys that patches allow to open channels, like bulsat irdeto channels
    if you open the softcam in notepad you can see the sections and keys, and you can copy and paste in new ones as they change, which is what the fileguys do
    so the channels you "lost" were probably the ones opened by the softcam, and you needed to enable ucas and have the latest softcam installed to reopen those channels
    and you need to put in biss keys by remote control to open any biss channels, there is a thread on here by another member that has those keys and channels listed too
    so with the march 2012 patch, the ucas enabled, the latest softcam installed and any biss keys put in by remote control you will open whatever is open
    Ok, I leave it to the experts, tooo complicated! It was only that since I changed to the latest mar2012 patch about 2 weeks ago and the latest softcam, I lost my austrian channels and now I must stick in a card from an other receiver to receive these channels. Is it possible if I go back to the previous patch nov 2011 and the previos softcam my system will be reinstated?
    • ramjet
      • 2995
      #62
      I cannot see that having anything to do with the patch, as it does not open any channels at all
      the only way to open channels using the patch is to use the softcam and add any biss keys, there is no other method
      other than that its add a card like you have done, or its get internet "help" which we cannot discuss
      so to answer your question , no, I dont think it will make any difference to your "austrian channels" issue
      that problem is something else entirely, or it may be that you havent turned ucas on, or maybe you havent added a biss key ?
      or maybe your softcam isnt up to date ? http://www.digital-kaos.co.uk/forums...3/#post1841494
      if you had said which channels and which satellite they are on then maybe we could have tested them for you and try to help with that particular problem
      but you never said which they are or where they come from
      • Einsvonzehn
        • Dec 2011
        • 23
        #63
        ORF1,11,111, ATV,ATV2, Puls4. 19,2E
        • ramjet
          • 2995
          #64
          all working fine here using mar 2012 patch, ucas turned on and todays softcam installed
          pressing info twice tells me they are decoded by ucas, which is the patch + softcam
          so if it works on mine, it will work on everybodys
          • Einsvonzehn
            • Dec 2011
            • 23
            #65
            I seem to get mixed up with the save and reboot, I have lost all channels again. No big problem but before I start, I noticed a couple of configurations. Could you confirm these ?re correct.
            Net sw Download menu.
            Name or IP address http://default
            download enter pressed.
            message: please check IP address.
            Client Setup menu.
            Type on
            login ID (pale grey not active)
            Connection Status Not Connected
            Register (enter)
            Questions.
            1 Should there be a valid IP address?
            2 Why does it say not connected, internet switched on and ethernet cable connected.
            • ramjet
              • 2995
              #66
              Client Setup menu.
              Type on
              Register (enter)
              Questions.
              1) that first part was online update from the spider server which is no longer active so doesnt matter what you put in there as its obsolete and no longer n use, just use usb stick updating as usual
              2) client setup is where you add your internet "help" (think of an agile aquatic mammal here) but we cannot discuss that on the forum so I cannot go into details
              but if you have nothing to put in then it isnt going to do anything
              ps:- I posted my channel list here yesterday so you could use that
              • Einsvonzehn
                • Dec 2011
                • 23
                #67
                Thanks again.
                No.1 is Ok then, no problem.
                But No.2 I did say The Type is switch on. But the Login is pale grey and not active.
                To enter anything whether aquatic or any animal. Is it important that I enter something here, as I cannot get FTA or scrambled channels, I get nothing at the moment.
                OR is this another problem.
                • ramjet
                  • 2995
                  #68
                  Thanks again.
                  no 2 is only important if you require net help from that s*a l*on" and is irrelevant if its not required. only you can decide if you are doing this task or not
                  if not leave them all set to none
                  if you are using these additions then input the details you are given into this section
                  I cannot elaborate due to forum rules
                  none of this has any influence on the receiver obtaining fta channels , or channels opened by ucas like orf on 19e in conjunction with a softcam, or if using biss keys like on pltv on 10e either
                  my advice is concentrate on getting those all working and ignore the client setup for now
                  • Einsvonzehn
                    • Dec 2011
                    • 23
                    #69
                    Hello again, I have everything working again but cannot view the austrian channels without using a card from another receiver.
                    Question. Should the UCAS autoroll be on, mine isnt but the UCAS is.
                    Have I made a mistake loading the latest softcam. I hadnt unrared it as I read somewhere I shouldnt. But I had unrared the HD9000 File.
                    If there is a clear proceedure for dummies to reload these updates can you please point my nose in it.
                    • ramjet
                      • 2995
                      #70
                      ucas on - autoroll doesnt matter
                      yes , unrar or unzip the softcam and then load it, and orf should return
                      always unpack any files
                      • Einsvonzehn
                        • Dec 2011
                        • 23
                        #71
                        Thanks again, everything running fine. I must say that 'xbxzotje'
                        posted a detailed instruction sheet for updating patches etc.
                        This is very clear and precise.
                        • so1o1
                          • Feb 2013
                          • 4
                          #72
                          Hi,
                          I take it March 2012 is the latest patch?
                          • bandit boy
                            • 155
                            #73
                            No more updates after that date march was the last one
                            • spider2001
                              • Feb 2013
                              thanks, this worked really well
                              • bateria72
                                • Dec 2016
                                hi is any softcam CONAX for starview hd combo
