16e
  • brin251
    • 122
    #16
    i got my tring back wahey only need viasat now on 4.8 that is
    • stavtoon
      • Sep 2011
      • 49
      #17
      my Tring is also back but lost Supersport HD as its on a different transponder number so will keep an eye out for these.Quality 70% so not much better than before unless its quite in position yet.
      gigablue quad
      gigablue se in bedroom
      orbital 1m motorized
      • ramjet
        • 2995
        #18
        plenty of info on the forums etc about all the changes that have happened over the last couple of days including all the new transponders that have replaced the old ones
        the old sdatellite has now been switched off and is going to be moved , and the other two are staying to provide data services
        so get yourselves the new W3C transponder lists and rescan , or do a full scan in order to get the channels back
        it just means you will have to do some work like the rest of us have had to do , but once complete your spiderboxes, technomates , blades and dreamboxes will all work fine again , especially the spiderbox
        the satellite is at 15.8 east but set your spiderboxes to 16.0 east same as before or the channels wont decode
        signal levels are generally much better than before the change occurred
        • dick b
          • Jun 2009
          • 2462
          #19
          tring good and strong on 11.283V 27500.
          digitalb ok on 10.803 H 27500,10.762 H 27500,& 10.845 H,
          no signal on the DVB-S2 TPs
          • mdt
            • 3034
            #20
            here,s the predicted footprint maps for w3c at 16e, regards mdt
            • jupiterr
              • Oct 2011
              • 4
              #21
              Hi All
              The 'B' beam at 16e gone from south eastern Spain, The 'A' Beam very flakey..odd Transponders available on a clear day! thats using a 1mtr dish.
              Alignments ect have been checked...........
              Jupiterr
