Calling sat installers from greater Manchester
  • spookymulder
    • 13
    i am looking at purchesing a technomate off ebay ( not to sure about which model yet , still learning about patching etc)
    i need someone from the Manchester area to hook me up with the right size dish 80cm +
    the right LNb to get multi sat - i have heard you can have upto 4 Lnb on a bracket...i cant afford a motor system at the moment....
    and set the dish up right on the wall..i was looking at doing it myself but i am clueless...so i want to get the pros in
    i have been told by my local installers for a 80cm bog standerd dish , lined up right, installed will cost me 160.00
    is this fair , or is it a little pricey
    is there any good dish installers within the manchester area
    kind regards - any advice
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5611
    First things first..no need for multi lnb.. Just 1west with a cam will do you fine as the nearby sats have nothing much worth while..
    You can easily install the dish yourself within 2 hour..it only gets hard when a motor is introduced..
    Just throw the bracket up..get a compass and find south..make your lnb vertical and make sure the dish is facing about 15degrees higher than a sky dish then move the dish towards south and keep moving it west until you get signal..use the tp 11785v28000 as the signal is amazing..
    Thats it..
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • spookymulder
      • 13
      what size dish would you recommend, i get throwing a bracket up , but what is a 1west with a cam
      what Lnb would you recommend
      do you think 160.00 is steep for a 80cm dish , plus intallation
      thanks for the advice by the way , did i say i was a newb LOL
      • .: JaCkPoT :.
        • 5611
        160 for dish and motorless installation is rip off..
        1west is a position of a satellite..the best one at the moment..this is one degree to the west of south..a cam is like a card which goes into your box but its slightly different..the tm patch will open digitv but with a cam you will also get another package called canal nordic on 1west giving you all prem games you could wish for..
        ___________________
        DM800s HD
        Openbox S10
        TM500
        DM500s
        Maxx 110cm Dish
        • spookymulder
          • 13
          would a old style sky dish do , one of the bigger old style, just bang that up on me wall
          looking at the technomates on ebay , this is the one i am looking at bidding on
          Technomate TM5000DACI Satellite receiver on eBay, also Digital Receivers, Satellite Boxes Receivers, Satellite Cable Freeview, Consumer Electronics (end time 18-Jan-09 17:30:00 GMT)
          is that a good one
          • .: JaCkPoT :.
            • 5611
            Oh and you will need a 90cm dish and a universal lnb
            ___________________
            DM800s HD
            Openbox S10
            TM500
            DM500s
            Maxx 110cm Dish
            • .: JaCkPoT :.
              • 5611
              No thats the old 5000receiver.you need a 5400ci usb..
              And a old sky dish would work with c different lnb but its always better to start properly
              ___________________
              DM800s HD
              Openbox S10
              TM500
              DM500s
              Maxx 110cm Dish
              • spookymulder
                • 13
                This is the one i am going to buy , it comes with cams built in
                and already patched, just need to find a 90cm dish , and a universal lnb thanks
                TECHNOMATE SATELLITE RECEIVER TM 5400 CI+USB PATCHED on eBay, also Digital Receivers, Satellite Boxes Receivers, Satellite Cable Freeview, Consumer Electronics (end time 31-Jan-09 19:09:22 GMT)
                • .: JaCkPoT :.
                  • 5611
                  There is no such thing as having a cam built in. It could be a softcam which only opens what the patch opens..google diablo cam and cas3 programmer..you will need them too but for the meanwhile you can live without the cam.
                  ___________________
                  DM800s HD
                  Openbox S10
                  TM500
                  DM500s
                  Maxx 110cm Dish
                  • spookymulder
                    • 13
                    i was going off this technomate that is on ebay , that claims it has 3 clams built in??
                    VIACCESS , ASTONSECA, CONAX... cams
                    is this for real
                    • benny/9
                      • 1964
                      is this for real
                      it means the receiver will work with these cams mate
                      also the card reader is multicrypt and works with most cards on the market i have found that all technomate receivers work with all cams, but even though there are two cam slots most receivers will only work with one cam
                      in he receiver at a time, hobby cams a very dominat and wont work if there is anouther cam in at the same time. it's aready been said the best cam to give you everything thats available is the v2.3 diablo cam light and you said you need a installer to set it up try D&C. buxton road disley for a price
                      Please Read Carefully!
                      • spookymulder
                        • 13
                        misleading that ebay auction dont you think, saying 3 cams built in, i will give that a miss then...
                        thanks for the advice , i will give that installers a ring , see what they say,
                        lost at the moment, if i get the right technomate..that would be a start LOL
                        • benny/9
                          • 1964
                          there's no need to feel lost mate it is confussing at first, a lot of the tech jargon is confussing when we buy a satellite receiver we buy a free to air receiver and we then need patches,cams or cards to get the channels open and view. for a first box i would say the
                          technomate is the easiest receiver to use and set up. and to go for. and as i said they work with all cams, the problem now is we have had lots of the providers changing there encryption to nagra 3 etc; and there channels cant be opened even with the receiver patched.
                          that is why a lot of technomate users now have a diablo cam this opens lots of channels on different satellites but like anything else if you dont pay for a official subscription these channels could also go down and we could loose them as well. there are no gaurantee's in this
                          hobby we have had a very good run with lots of chns open and now there is'nt much so now it's wait and see if or when we get some of the channels we have lost back open again.
                          • mikeyb
                            • 161
                            Im in the same boat and I am doing a lot of reading. Im not rushing in but the CAMs are confusing for me. Why do you have diablo cam? Is it not possible for it to be a softcam?
                            • .: JaCkPoT :.
                              • 5611
                              We dont know why the diablo cam opens more than softcam but there is a saying'you never know whats around the corner'..
                              ___________________
                              DM800s HD
                              Openbox S10
                              TM500
                              DM500s
                              Maxx 110cm Dish
