what protek model do you have?
protek 9760HD short channel list.
your installer has not done a very good job has he you should be picking everything available up,Just upgraded my dish from a 13/19 monoblock to a system with a motorised dish with single LNB.
My installer set the Motorised System option to USALS, and amended the long/lat figurers.
Unfortunately, I don't know how to scan for channels on, say, 16 or 23.5, and only have what I had before on 13 and 19. Can anyone help get me started?
Cheers!
if you put in dickb,s channel list in and you still cannot pick the other sats up then you should call your installer back to finish the job off.
........bj1Comment
Thanks... I have been crazy noy knowing what to do ...I hope it helps, the original version was 2.0 for the protek 9760, I got the BorisT, but nothing changed... I will try tonight again...
Thanks mateComment
[QUOTE=Halladay;1616951]Thanks... I have been crazy noy knowing what to do ...I hope it helps, the original version was 2.0 for the protek 9760, I got the BorisT, but nothing changed... I will try tonight again...
Thanks mate[/QUOTE
yeah boris firmware v 17 is the latest
but those channel lists I posted earlier are a bit out of date
so heres some later ones 629 the 4 sat list is right uptodate and the one I use there is still a lot of rubbish on it but the favorites may be useful and the transponders are right(at the moment)
the 616 file is for motorised and not quite upto date as I dont use a motor on the protek(theres more than enough on 4 sats)
the 4 sats are 13E,16E,19E & 23.5E
if you are using a motor check your co-ordinates after loading a channel list(you can use the 4 sat list with a motor if you want)Last edited by dick b; 5 July, 2012, 16:19.Comment
could i ask a couple of questions please, im a dm man i must say ..
but if so here it comes .
can i add a cline on these boxes .
can i use emu mgcamd 138
also how often do you have to update firmware ,
and finally how reliable and what packages is this box clearing .
the reason i ask is i got one a few years ago and they stopped suporting it ..
just my luck ..
thanksdreambox 800 tech 500 ( ubuntu 10 .04)... 1 m dish v box 2 acuator ..Comment
