hello i have just fitting my motorised dish if i do a automatic scan will the scan, scan all satellite it find or do i do it manual thanks
motorised dish tuner
hello just a check to see if i have enter the longitude and latitude right in my dm800 on multimap is say longitude -2.75915908813477 and latitude is 53.4503173828125 do i put in my dreambox longitude has 002.759 or 002.800 and latitude has 053.450 or 053.500 thanks dkComment
put the 002.759 and 053.450 this should be fine you only have to round of to the nearest decimals on boxes with less
decimal spaces.Comment
your dish may be slightley out most likely your bracket not dead plumb you can offset this by adjusting your lattitude try adding .200 at a time untill your signal bar rises to its peak
so if your lat is 52.450 try 52 .650 and so on till you get it right, these sats that you are missing especially 26e have weak signals but 16e you should get on a 80cm+ dishComment
well mate theres no definitir list it depends on install and things like that 26e is a hard sat to getu should get 16e tho buddyComment
well you should get from about 42e to 30w , although some like 26e and 7w will be more troublesome as they are for the middle east and not the uk
usually with those you get some but definitely not all
42e and 39e are ok as long as the motor and dish are setup correctly , fairly strong signals in the uk , as is some of 5e too
30w , 15w , 12.5w , 5w , 0.8w , 7e , 13e , 16e , 19e , 23.5e , 28e , 39e , and 42e are the usual suspectsComment
