sly plus rec cheat
  • terriers
    • 580
    sly plus rec cheat
    hi everyone..
    just letting you all know about a little cheat if you have a spare sly plus box..if you ring sly and tell them your card is damaged ie your kid has pulled it out and snapped it.
    they will send you a new card at the cost of a tenner,and they only switch off the premium chanels on the old card,BUT STILL leave the recording function active.so you can put the old card in a second box and use it as a FREEVIEW RECORDER,,.RECORDS ch4 and 5now as well...mines been doing this now for 12months.....
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • Aug 2008
    • 5607
    Where do you find all these tricks on sky from? Mind you they maybe against the forum rules..
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • terriers
      • 580
      i used to work for them sadiq..
      • .: JaCkPoT :.
        • Aug 2008
        • 5607
        Ah wondering, thought for a moment you were rupert..
        ___________________
        DM800s HD
        Openbox S10
        TM500
        DM500s
        Maxx 110cm Dish
        • terriers
          • 580
          ...there is also a code you can put in one of those nice hd remotes so it will work on a sky plus box!!..
          • .: JaCkPoT :.
            • Aug 2008
            • 5607
            Tell us it then
            ___________________
            DM800s HD
            Openbox S10
            TM500
            DM500s
            Maxx 110cm Dish
            • terriers
              • 580
              right then.....
              first press the tv button on your hd remote,then press select and i button together and it will give 2red flashes,then press button number1 and hit the select button and it will flash twice again,and now it will work on your sly plus box.to change it back to hd just go through the same process but put in number 2 this time.......................
              • .: JaCkPoT :.
                • Aug 2008
                • 5607
                cheers mate...tell us more!!!!!!!!
                ___________________
                DM800s HD
                Openbox S10
                TM500
                DM500s
                Maxx 110cm Dish
                • terriers
                  • 580
                  do you know how to get a sly plus box out of standby?? if not i will tell you...........
                  • .: JaCkPoT :.
                    • Aug 2008
                    • 5607
                    On button?
                    ___________________
                    DM800s HD
                    Openbox S10
                    TM500
                    DM500s
                    Maxx 110cm Dish
                    • terriers
                      • 580
                      ...i mean if your box gets stuck in permanent standby which sly plus boxes do quite often cos theyre crap..........
                      you have got 5 buttons in a group up,down,left right,and centre.
                      power your box down,then press left and right button together keeping them pressed in while you power the box back up.it might take a minute or so but eventually the center green light will start spinning around and the recording light will come on.at this point you let go of the buttons and press the center button and the box will do a factory reset and spring back into life!!
                      you will lose any recordings you had,but if ur not insured it will save you 60quid.........................
                      • kah22
                        • 9
                        Originally posted by terriers
                        hi everyone..
                        Would that work if you were preparing to jump ship with Sky and go to FreeSat?
                        Say you phoned them an month in advance of jumping and paid for a new card would the old one still continue to work after the contract had ended; I mean still continue to record?
                        • terriers
                          • 580
                          yeah cos the old cards already been switched off,just recording still active
                          • kah22
                            • 9
                            Thanks terriers
                            Would that also mean that stuff you had recorded onto a Sky+ box would not be lost ie you would be able to play it back?
                            • terriers
                              • 580
                              unfortunately you would only be able to play back the free to air stuff you have recorded ie bbc itv ch4 etc...........
                              why dont you just get a freesat recorder in the first place to save u all the trouble,they have 4 times bigger harddrive and look much better,also it has a common interface so if you ever want pay tv u just buy a cam....
