motorised dish ~~~~ed
  • tool37
    • 139
    hi all, on friday motorised dish stopped working (typical, bank holiday) was watching 13.0e when signal started dropping from 80% down to 20% then after 5 mins no signal at all tryed switching to other sat, but getting no movement, tryed again today and it started moving again for 5 mins then stopped, tryed reseting by holding 2 buttons in for 5 secs and powering down but still no response, has anybody any ideas what has failed so i can repair myself or will i have to phone the man that fitted it, its about 12 months old, any help welcomed, thanks
    Have you tried another box? It could be your box or it could be your motor
    • tool37
      • 139
      thanks m8, i have not tryed another box, got a vu duo, which ive had for 12 months with no problem, got fixed dish on tuner b which is working ok
      • dick b
        • Jun 2009
        • 2462
        I"d start off by checking all the lnb/motor cables for proper contact.
        • Nutsandbolts
          • Oct 2011
          • 1168
          Hi. Check green light on motor is on and is not flickering as this indicates loose cable connections. If motor is 12 months old i would be surprised if it has broken down unless water has got into it. What make is it and are you using USALS or 1.2? Regards.
          • tool37
            • 139
            Hi m8, checked lights on motor and getting no lights at all, using 1.2, thanks
              whats the make of motor you got m8 ?? some motors have a small pin hole on them to reset the motor..
              • tool37
                • 139
                I can't see no stickers on it, I've looked for a reset hole, and can't find one, read that other motors you have to push the green and red light buttons at the same time for 5 secs, which I've done but still no joy, just checked for lights, but no sign of life, gonna phone the chap who fitted it tomorrow and see what the problem is, done my head in, bank holiday aswell
                  this shows the reset on the right
                  • Nutsandbolts
                    • Oct 2011
                    • 1168
                    Hi. If as you say there is no lights on the motor this is usually to do with cable connections. The motor gets its power from the receiver so make sure the cables are connected properly. You can test the motor cable by connecting it to the LNB socket on the motor and see if you get any signals. Regards.
                    • tool37
                      • 139
                      Hi m8, just connected motor cable to lnb, and I'm getting signals, so is it the motor thanks
                        Sounds very Much like the motor has gone and your motor feed to LNB direct connection is fine.
                        • tool37
                          • 139
                          Hi, phoned the installer today, he came out and confirmed the motor has gone, he fitted it just over 12 months ago so no warranty, he said he is fitting a technomate motor, are these motors any good, or shall I tell him to forget it and wait and get a decent motor that lasts, the last motor could not have been any good for it to only last that long, anyway thanks for all your time and input
                            If your going for a TM then get the 2600 which has metal gears, I prefer the Superior Dark Motor for just a few quid more this is also metal geared but extremely silent, Its a clone of the Clarke-Tech HH360 from germany where as the Technomate is a Motek Clone.
                            • tool37
                              • 139
                              Thanks m8, gonna phone him first thing and tell him to get one of these motors, as I said he charged me ?200 for the 1.10m dish and motor last year and you would expect the motor to last longer, would set it up myself but it's the alignment what's hard not having the right equipment, friend said to go to alsat shop and get dark motor, but it's waiting for it to come, thanks again
