Gonna throw sky box out the window!
  • sporTTy
    • May 2012
    Hello
    I've searched for ages now looking for a way to sort out my sky+ box on here but i'm not sure i've found the exact answer, so here's my question.
    Earlier this week it was pouring and i lost sky altogeher on both boxes. ( I have sky+ downstairs via subscription and an old sky box upstairs where we jusdt get the freeview channels). Thought it was the weather and so didn't worry too much.
    Since then, the channels are back but go pixellated and freeze. Some channels are worse than others and some i get the 'no signal being received' message.
    I was going to do the reset thing as posted on here and was ok about losing all my recordings. My question is this though.. is it a box issue? My thinking was it probably isnt as both my boxes are playing up. It must be something to do with the dish?
    Please help. I am about to throw both the boxes through the windows (much to hubbys disgust!).
    Answers is simple English for me please! Many thanks in advance for your help
    Never underestimate the power of stupid people in large groups.
    Sounds like you might need to tweak your dish a bit and check for any water ingress ..
    • mark8393
      • 2305
      sounds like dish/lnb problem. realign if needs be. check lnb and coax cable as well
      • ramjet
        • 2995
        I would say deffo a dish and/or lnb problem , or cables , or all 3
        probably not the box , so test the box at somebody elses house on their sky feeds for comparison
        if it works there and not at yours , its your dish/lnb/cable at fault
        throwing them through a window only adds to your woes , it wont fix the problem
        so get the dish and lnb and cables checked or replaced, and aligned
        with the recent bad weather , thousands of installations will have need similar attention , I have had to tweak a few myself , and only yesterday changed my lads quad lnb !
        • sporTTy
          • May 2012
          So can i just climb up the ladders and jiggle the dish? Get hubby to stay indoors and shout when it works? Like a 'Carry On' film?
          What is this about water ingress... how do i know if that is the issue and how do i fix it?
          Sorry if this has all been said before.
          Plus Sky said never to try and move the dish myself. I must pay them to fix it for me. I soooo want to fix it myself and save ?65!
          • ramjet
            • 2995
            sky wont advise you to do anything except pay the cash out , certainly not any diy
            if its the dish , then careful tweaking whilst watching the tv can be done
            water ingress means water inside the lnb or cable , or both , and so a new lnb may be required and also the cable ends remade or worse still new cable fitted from dish to sky box
            I can do it myself , many on here can too , the average miss noidea ? maybe not
              Originally posted by hobbers123
              ha just writing this to gain access
              ha just reported you for a crap 1st post
              • sporTTy
                • May 2012
                I'm a definite Miss Give It a go, but i know my limits! I'll try the dish jiggling bit and if that doesn't work i'll get a man out who can do it.
                Is there a place on here where i could find a local person who could come and help me?
                • PremierD
                  TAMINATOR
                  • Jun 2009
                  • 13143
                  Repost you muppet .. ..
                  Oh ! you cant't you're all grey
                  • short360uk
                    • 313
                    I would prop deffo say water in cable had the same problem myself in the past and its only happend since its been rainin, and it has been bad up this way
                    • tuffdisk
                      water in the cable definate im a sky engineer
                      • hooley
                        • 470
                        No, youre not
                        • rigsby71
                          • Mar 2009
                          • 676
                          I would say try...
                          Dish out of line...Lnb faulty or water...Cable water ingress.
                          in that order.
