*New* Redline T7600 HD
  • Rehman0007
    • May 2012
    Rehman
    Hi pagolookley411: I received the same massage Mismatch File I contacted supplier and he helpmeet.i just dida factory reset and downloaded this new firmware into my STB as mentioned in the guide.it works a treat,hope it work for you as well thanks Htt://s000.tinyupload.com/?file_id=02733522537258487520
    • tony34567
      • 102
      #32
      The above link is not working typo error.
      Working link, fix typo error.
      Release Date: 18/5/2012
      Firmware: Redline_T7200_V2051.bin
      Audio Language Bug fix
      Hide super setting details .
      • djslytv
        • Nov 2011
        #33
        nightmare with firmware upload
        hi i've tried to upload the firmware so many times and i keep getting miss match file i've tried factory reset before installing i contacted the supplier and all he said was to post a problem in this section is there a correct way of uploading this firmware
        hellllllppppp as i'm going bonkers
        • Manic01
          • 5117
          #34
          Tell the supplier he should sort it out, he sold it to you.
          • tony34567
            • 102
            #35
            Mismatch file error
            To djslytv,
            First download the tutorial mentioned in ''Satsmo'' post ''1'' follow the text guide then follow post 25 . hope this will fix the error.
            Good Luck
            • djslytv
              • Nov 2011
              #36
              thanks for reply
              i have sorted the firmware out now .
              only problem i have now is that cccam keeps freezing after 5mins i have a c:line for sly tv off a friend and it freezes up.
              in server setting it say's connecting .then connect failed
              • djslytv
                • Nov 2011
                #37
                can the cccam be downgraded in this box?
                • tony34567
                  • 102
                  #38
                  CCcam freezing problem
                  To djslytv, I have no problem with Latest firmware version B_V2.0.51.bin, fixed cccam freezing issue. Make sure you installed latest firmware. To know stb f/w go to menu/settings/upgrade/version/ F/W version B_V2.0.51.
                  • jayden2yk
                    • May 2012
                    #39
                    channel listing for redline box...
                    hi everyone...
                    does anyone have a upto date channel listing for the redline as i have too many damn channels that dont work and a lot missing...
                    thank you
                    • tony34567
                      • 102
                      #40
                      Redline S*y UK and Astra 19 Favourite channel List
                      Have a try this channel list.
                      Its a bit older . If someone have latest channel list share it here.
                      final sly 28.2.rar
                      astra19 channels list.rar
                      • spaceman
                        • 11
                        #41
                        box is not working after trying an upgrade.. all i get is a blank screen.
                        is it worth trying to recover using the eaglehd rom.bin used for recovering?
                        • tony34567
                          • 102
                          #42
                          mate if you tried all solutions mentioned in this thread and still have a problem contact supplier he should sort it out.
                          • spaceman
                            • 11
                            #43
                            returned the box and supplier has refund the money.. no complaints.
                            • Dave01iver
                              • Jul 2012
                              • 8
                              #44
                              Nline
                              I have got all the super setting and have entered all my Nline details, but it still is not connecting, the redline in on the network so it is not that, any ideas?
                              • tony34567
                                • 102
                                #45
                                Is it a working N line?
