you will also need 2 dishes to get the best out of a twin tuner you could buy 2 sunray 800se for ?280 to ?300 direct from PRC
Which box is best for the following?
do you need to have two tuners to record two channels..?
and with the VU can you record channel and watch a recorded programme at the same time..?Comment
a single tuner allows you to watch one channel (or record one channel)
the reason for wanting a twin tuner is to allow 2 different channels to be recorded, like sky plus does, or one channel to be recorded and another different channel to be watched
(especially on different transponders)
you do not need 2 dishes for a twin tuner box, but you do need 2 feeds from lnb,s, which can be from the same lnb like sly which usually uses a quad lnbComment
@Rizwan007 - your budget will buy you most boxes available.
if you want to watch something and record something else at the same time then a twin tuner is a must.
I would either go for a VU Duo Genuine or clone, depends really if you care if one is a clone or not as they are almost identical and you would never know the difference as a user.
If going for a clone pay ?10-20 more and buy from a UK seller and not china for those just in case situations. satstore.tv is a UK seller of clones.
The Ultimo... i wouldnt bother, how often would you use 3 feeds? (recording 2x programs and watching another?)
In my opnion 3+ tuners is when you have both a fixed and motorised or similar setup.Comment
