EagleBox HD 800
  • iGame
    • Mar 2012
    • 85
    EagleBox HD 800
    Im thinking of getting this, but just wanted to know who else has got it and is it similar to a dm500s.
  • ramjet
    • 2995
    its nothing like a dm500s
    the dm500s is SD not HD, and runs linux images of varying sorts, with plugins
    the eagle 800 HD runs bespoke software patches like a blade 7000s or a spiderbox do
    • briz
      • Jun 2012
      • 38
      I looked at these as a cheap box, but support didn't seem too good. Most advice I read was to go with Openbox at that budget so I went for Skybox F3 which I'm happy with
      • iGame
        • Mar 2012
        • 85
        the prices are similar with this and the open box so which box is better?
        • mdt
          • 3034
          you get what you pay for m8... id go with a dm800pro if you can stretch to it although if i had to choose id say the eaglebox on build quality if its anything like the spiderbox. regards mdt
          • iGame
            • Mar 2012
            • 85
            Yeah that the issue I'm low on cash I might b getting the BM500s soon any review on that
            • ramjet
              • 2995
              its basically a clone of the dm500s, and runs dm500s images, and is SD not HD
              as mentioned earlier , you get what you pay for in this game , and SD boxes are all old hat nowadays
              if you buy cheap you normally get an SD box, usually a clone and usually running linux images, or something like an openbox that uses bespoke firmware instead
              anything decent will cost more than ?100 new , maybe ?120 to ?150 , or less if secondhand
              it is possible to buy a cheap starview combo and use it like a spiderbox, or buy a second hand spiderbox where the gift has run out. these options are better options than an SD clone dreambox or openbox or clone of similar types
              ideally you buy a blade bm7000s, or tm5402 , or spiderbox , or a clone dm800HD or clone vu , or original dreambox or vu
              best bet is wait until you can afford it and buy something decent, do nor be constrained by budget or you only end up regretting it
              • jovie
                • Oct 2008
                • 100
                if you want a good cheap box get a cryptobox 400 regards
                jovie on ebay
                • Bann32
                  • Oct 2011
                  • 518
                  a 800hd clone if you can push the budget, steep learning curve but a far better box and you will learn more from it.
                  If your planning on using the eagle box as a stepping stone, id get a dm500 to get you up and running and save the rest towards a better box
                  Others will have thier own opinion that is mine
