Im thinking of getting this, but just wanted to know who else has got it and is it similar to a dm500s.
EagleBox HD 800
its nothing like a dm500s
the dm500s is SD not HD, and runs linux images of varying sorts, with plugins
the eagle 800 HD runs bespoke software patches like a blade 7000s or a spiderbox do -
DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
its basically a clone of the dm500s, and runs dm500s images, and is SD not HD
as mentioned earlier , you get what you pay for in this game , and SD boxes are all old hat nowadays
if you buy cheap you normally get an SD box, usually a clone and usually running linux images, or something like an openbox that uses bespoke firmware instead
anything decent will cost more than ?100 new , maybe ?120 to ?150 , or less if secondhand
it is possible to buy a cheap starview combo and use it like a spiderbox, or buy a second hand spiderbox where the gift has run out. these options are better options than an SD clone dreambox or openbox or clone of similar types
ideally you buy a blade bm7000s, or tm5402 , or spiderbox , or a clone dm800HD or clone vu , or original dreambox or vu
best bet is wait until you can afford it and buy something decent, do nor be constrained by budget or you only end up regretting itComment
a 800hd clone if you can push the budget, steep learning curve but a far better box and you will learn more from it.
If your planning on using the eagle box as a stepping stone, id get a dm500 to get you up and running and save the rest towards a better box
Others will have thier own opinion that is mineComment
