Hi guys, trying to solve a problem and have asked elsewhere, but a problem aired is a problem halved (I think thats how the saying goes)
Ok recently purchased
Genuine Vu+solo
blackhole image 1.7.6
Triax 110cm dish
Alsat dark superior led motor.
Dishpointer co-ordinates
000.0251 e
051.5414 n
Dish Setup
Ive managed to get the dish up, everything seems to be plumb and level. Dish is installed using coordinates from dishpointer, so correct latitude on motor at 51.5, dish is then set to 35-7.4 so that is set to 27.6
Cable setup
the cable setup is as follows, and I have double checked all of this to make sure f connectors are in snug and the right amount of sheathing removed.
back of vu+ solo box > motor 'rec' (28m cable)
motor (lnb) > lnb (1.5m cable)
STB Setup
Configuration Mode: Simple
Mode: Positioner
Latitude: 051.541
NORTH
Longitude: 000.025
EAST
then
I did the following to zero the motor
Press Menu
Select Setup Press OK
Select service searching Press OK
Select Positioner Setup Press OK
Select goto 0 Press RED Button
I could see the dish move slightly to the right then back again.
Channel setup
Downloaded crossepg
Updated using openxml
Downloaded latest catseyes channel list and uploaded to box (thanks catseyes and all involved)
The problem
Pressed the channel + button, selected satellites, chose thor 0.8> services > bbc world news
At this point I could hear the motor click, I thought nothing of it as the dish would only need to move slightly.
Went up to the roof to fine tune the signal, but noticed that the motor dial was still on 0 and hadnt moved even slightly.
I tried pressing the manual east and west button, but it would click once and you could see the dial go up/down by 0.1 tried keep it held but nothing.
So I went back to the STB, rebooted, went to positioner and used the remote to manually move the dish west, this worked. I went to zero the motor again, but again the same problem occurred, all I hear was a click (the dish at this point is about 20w.
Went back to the roof and after clicking away at the button managed to get the motor back to 0 (the STB was in the positioner menu at this point)
Now back at the STB I zero the motor and it works, now I select bbc one on Astra 28, thinking the dish should visibly move to the east, but nothing, I do however hear a click and a flashing satellite dish image on the screen.
This is the point I gave up. Any help will be really appreciated. Ive tried using a shorter cable with the same results.
Could it be USALS not working right, receiver not pumping out enough juice or co-ax not carrying enough of it, or the motor being kanckered?
everything is new.
Genuine Vu+solo
Triax 110cm dish
000.0251 e
051.5414 n
Dish Setup
Cable setup
STB Setup
Mode: Positioner
Latitude: 051.541
NORTH
Longitude: 000.025
EAST
then
Press Menu
Channel setup
Downloaded crossepg
The problem
everything is new.
