maxx1000 / protek 9600 / nanoXX
  • mdt
    • 3034
    #76
    Originally posted by galini
    Hi everybody,how do I load this last firmwares in the 9700HD IP ? Thank you.
    firstly, hi and welcome to dk. now unzip the file and then load it into the ROOT folder of the usb stick. now put the usb stick in the usb slot at the back of the stb. press, system info,firmware upgrade, then select the file and press ok. when the file has loaded the stb will re-boot. make sure you enable the network settings and then press ok, then blue for the package list. heres the latest file for your stb, enjoy!! regards mdt
    • almias
      • Feb 2011
      #77
      I hope I want to help the new key 60
      • mdt
        • 3034
        #78
        your box should auto-update to the latest keyfile. try switching your box off at the mains and then on again and it should update, if not you can use the webloader to download k60 directly from the board server. regards mdt
        • almias
          • Feb 2011
          #79
          Optimized device does not have an automatic update and I need to raise the key manually
          • mdt
            • 3034
            #80
            are you using t72 software and is the au function set to on in the menu,s?? regards mdt
            • Stallone12
              • Apr 2011
              Thank you
              Thank you very much.
              I will try it as soon as i get home.
              • georgekamal
                • Oct 2008
                #82
                dear friends,
                from where i can buy this box in UAE?
                regards
                • mdt
                  • 3034
                  #83
                  Originally posted by georgekamal
                  dear friends,
                  regards
                  you can get a 9600ip clone for around ?80 gbp off *bay but i dont know what it would cost to ship to u.a.e and if it would work as the authoraties are rather strict on certain things. have you tried your local sat suppliers as they could advise you better than me. regards mdt
                  • georgekamal
                    • Oct 2008
                    #84
                    thank u for the reply...by the way, any shops there who selling the box IP9600?
                    regards
                    • mdt
                      • 3034
                      #85
                      regards
                      just go on *bay uk and search for maxx1000 or legend satellite reciever. regards mdt
                      • nai22
                        • Oct 2011
                        hi all, someone got latest firmware for the maxx 1000
                        my receiver got 0700 error. maybe flashing can solve this.
                        bye
                        • mdt
                          • 3034
                          #87
                          bye
                          flash the software in this thread and the box should then auto-update to the latest version. regards mdt
                          • csalter456
                            • 4
                            #88
                            9600ip
                            hi i know all these boxes are now dead ive been reading somewhere there is a third party firmware to instal and box can i be used as a cc "?m unit is this true if anybody does know could they please advise many thanks in advance
                            • mdt
                              • 3034
                              #89
                              the boxs are not dead and you can revive all your channels and get 1 extra package from greece if you get a id file then change your software. id files last at least 6 months(all being well obviously). regards mdt
                              • stopel55
                                • Nov 2011
                                Originally posted by baroni701
                                Does anybody know if this box can get any channels. I haven't used it in over a year due to server going down and mac filtering. I was able to test it on cs pay server but got fed up and ditched the box. I am thinking of trying to ressurect it or go for a Dreambox - any ideas?
                                hi, you could try this as it does work sometimes. load the me-to-eu file the t70 then k46 and do a factory reset after each upload. let us know if it works, regards mdt
                                Thanks for the tip !
