Alligning dish, which channel/transponder?
My dish is slightly different than that, here's a pic of the markings it has, http://cdn-0.create.net/siteimages/0/8/7/8761/89243.jpgComment
dont worry about the markings.. use CH4HD on 11.126.v.23000 dvbs2 to find astra2f and CBS ACTION on 11.222.h.27500 dvbs on eutelsat 28a to fine tune. its a zone 1 m8 there a piece of cake just take your time and make very small movements left/right,up/down untill you find the bird and ajust to peak and squeeze every drop of signal from cbs action. @digi m8 C4HD is booming in here at 20 DB regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
Sorry mate my mistake i read your original post wrong the pictures i took are of a Zone 1 and not a Zone 2 which do have the elevation markings.
@mdt it should be booming in i aligned it for you :-) LOL
No worries, from your experience are the elevation markings accurate?Comment
Tried again today but no luck still.
I thought the cable was faulty but tried this on my virgin box and worked fine. The vu+ is fine as this was working perfectly with my old dish.
Is my LNB faulty?
The other thing which i found strange was that i bought a satellite finder from screwfix and that didnt work either. Actually, when i plugged it in, it showed nothing as it seemed there was no power going to it.
I have been doing some research and it seems like the meter requires power from the box but the vu+ does not always give power to the LNB as mentioned here, Power to LNB on always possible?
Is this correct?Comment
if you leave the box switched on tuned to channel 4 hd with the osd set to no timeout then if the cable/dish/lnb are fine then you will pick the signal up eventually. imo those cheap signal meters are not great as they give readings of the floor. ive fitted a 1m motorised system using nothing than the osd quality meter and although not ideal and very time consuming it is possible. without a proper field meter theres no way to test the lnb other than recieving a signal,regards mdtTried again today but no luck still.
Is my LNB faulty?
Is this correct?DM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
Got it working!!!
Finally got it working, what a long and stressful day.
Went and bought a satellite finder but it didnt even come on, i thought it may be faulty. I tried to align the dish manually but no luck so had to call an engineer who charged me ?30 to align.
He said i was getting over 90% quality but still the vu+ couldnt get anything. I did a full scan but it only found channel 5 which was strange.
I then borrowed my neighbours sky digibox and it worked which meant my install was all fine it must be a faulty box. I was disapointed as the box was working fine before. At this point i plugged in the satellite finder to test it and it worked fine on the sky box. This re-confirmed that my vu+ was faulty.
As a last ditch attempt i plugged my vu+ back in and it started to WORK. I was getting more than 90% signal quality on most channels and picked up even more channels than previous.
I just can not believe this, but happy nevertheless. I also tried the satellite meter again and this time it was working off the vu+ so happy days.
What a really strange day!!Comment
