nannoxx 9600 ip
  • philipgr
    • 72
    #16
    nanoxx
    hello can somebody tell me what loader to use with the nano and where to get updated s/w cheers
    • baroni701
      • 41
      #17
      Originally posted by terriers
      Hi m8....you need these 2 bits of s/ware on your box to make it work again...they are t57 and k19...you will be able to load this s/ware onto your box using the webloader if your current t s/ware is in the fifties say t55...they are available at www.***downloads.co.uk
      Also to get your ***server to work you will have to set up the newcamd settings ie input server details and switch it on..note the free server wont work while newcamd is switched on...to view free server just switch newcamd off..
      Tried that but no channels unlocking - does anybody have BorisT3 S/W cos I know that worked
      • terriers
        • 580
        #18
        Its t59 and k19 you need now.....
        • baroni701
          • 41
          #19
          Still getting nothing - am going mad here. Do I need to convert my MAX to run on EU server? Does anybody have the old Boris s/w?
          BTW my webloader will not connect to box - could this be related to the problem?
          • martin-f
            • 535
            #20
            if you press menu then internet how many options do you have m8 also pressing menu you should have BT:1.34 SW:T59 K:19
            • baroni701
              • 41
              #21
              Network Connection
              AUTO Update Check
              Network Information
              NEWCAMD
              Proxy ConnectionS/W Upgrade
              and i do have BT:1.34 SW:T59 K:19
              Cheers
              • terriers
                • 580
                #22
                press menu internet...check network conn is on...and proxy conn is off and newcamd is off...then go to network information and look at your box ip address it should look somet like this 192.168.000.009...if not switch dhcp to static then back to dhcp and your ip add will have filled in...
                your box will now connect!!!
                On the webloader miss some of the zero,s on your ip address and it will connect...so the above ip will be entered as
                192.168.0.9
                • baroni701
                  • 41
                  #23
                  192.168.0.9
                  Done that and have a few i's beside some channels but none are clearing. Is there something this Maxx needs upgraded too??
                  Webloader is working again - cheers
                  • .: JaCkPoT :.
                    Retired Sat TV Addict
                    • 5607
                    #24
                    Please guys make sure you do not go into too much detail as the info may be against the rules.
                    ___________________
                    In the good old days, I had
                    DM800s HD
                    Openbox S10
                    TM500
                    DM500s
                    90cm FortecStar dish
                    Maxx 110cm Dish
                    Technomate 2300 Motors
                    • terriers
                      • 580
                      #25
                      dont know what else to suggest m8..you appear to have the
                      latest s/ware settings etc....maybe its somet to do with the boxes mac address(a problem in some maxx,s)..but if you have used this box before it should,nt be an issue....
                      I,v once read on a site that there was some s/ware available for the mac address problem,but cant remember which site..
                      • baroni701
                        • 41
                        #26
                        I searched for that b4 without luck after the server went down last year. I do know that the boris s/w did give me most channels with my paid server test account - I will keep looking for for the borist3 it might show up somewhere
                        • martin-f
                          • 535
                          #27
                          pm me for the boris t3 software m8
                          • .: JaCkPoT :.
                            • 5607
                            #28
                            the boris t3 is here m8
                            Im sorry if im wrong here but does this S/W auto connect to servers or do you still need to have your own servers? Im only asking as it may be against the rules.
                            ___________________
                            DM800s HD
                            Openbox S10
                            TM500
                            DM500s
                            Maxx 110cm Dish
                            • martin-f
                              • 535
                              #29
                              hi jackpot i do not use that firmware so i am not sure m8 so i have removed it as a precaution
