Recommended 100cm dish
  • dick b
    • Jun 2009
    • 2462
    #16
    dont put a motorised dish on a chimney stack mate and a perforated dish wont help much.can you do an over the gutter set up?
    • joetwizzy
      • May 2011
      • 322
      #17
      No, it needs to be high due to the trees outside my house.
      Bollox
      • sleepy1958
        • Jul 2012
        • 17
        #18
        Check with your local authority about mounting to the chimney because i seem to recall ANY dish mounted above troughing height will require planning permission.
        And you're only allowed 2 dishes to be wall mounted on your house, a sly dish and a dish upto 1 metre ( used to be 80cm ).
        • joetwizzy
          • May 2011
          • 322
          #19
          I don't want the dish blowing over so I think it might be out of the question anyway.
          • dick b
            • Jun 2009
            • 2462
            #20
            the dish needs to be approx twice the distance away from the trees as the height left from the bottom of the dish.if the trees are in the road outside the front of the house can your put the dish at the bottom of your back garden?
            • dick b
              • Jun 2009
              • 2462
              #21
              Originally posted by mdt
              i seen strange flaws with the inverto black ultra... wont pull in certain frequencies when other lnb,s will... on a install of a m8,s a couple of weeks ago would pull in 7 west but gave nothing whatsoever on badr4 and the install was 100% perfect in every other way using a 1m orbital on a stab 100 and a vu+solo2,regards mdt
              can second that on a twin output blk ultra using a TM5400 one output wont give 12.688H30000 on 39E but the other output does.
                #22
                Depends really some say dont but you can if you want, depends on how 'Healthy' so to speak your chimney is structurally and maybe re-mortared and even brick span say something like a double which spreads over your roof front to back should be no problem with a heavy duty double lashing kit just to be on the safe side.
                Try and get a phot uploaded of the chimney in question and see what the brick span is as well.
