Please Please Please help needed with motorised set up
  • mdt
    • 3034
    #16
    Originally posted by daley6522
    Hi Nutsandbolts,
    Thanks for that, I seem to have a decent reception on everything, I just can't get 12266 H 29500 which includes sly sports new HD, ESPN America HD and CH 5 HD.
    Have you any ideas please????
    Cheers
    Daley
    if you are getting all other transponders then its local interferance of a fault in the lnb/slybox. try 12.266.H.27500 on [email protected] or 12265 V 27500 on eutelsat9A@9e to see if you pick them up,regards mdt
    • jandial
      • 84
      #17
      Hi Nutsandbolts,
      Cheers
      Daley
      Try turning off any other reciever going to the lnb if there is any. The channels your talking about I had bother with but switched all other receivers off at the wall that was on the same lnb and they worked again....
      • Nutsandbolts
        • Oct 2011
        • 1168
        #18
        Hi. Have you tried looking at the TP throught the menu ie Installation - Setup and look for 12226H s/r 29500 and check if signal is being receiver for this TP. If no signal it means your dish/LNB may be misaligned and needs slight adjustment. Are the channels in your list or are you trying to scan for them??. In either case best thing to do is put receiver on one of those channels and then move dish with your hand to see if you get a picture on your tv or signal reading in setup menu.
        Regards.
        • daley6522
          • Feb 2013
          • 10
          #19
          Regards.
          Hi Nuts,
          Its in the TP list, so maybe just a smidge out, there not in the list thats or when i scan it just says 12266 H 29500 failed. ill check it out again in a few days as away till then.
          cheers
          Daley
          • daley6522
            • Feb 2013
            • 10
            #20
            nothing else connected, but thanks anyway
            • daley6522
              • Feb 2013
              • 10
              #21
              I tried loading these to find said channels and not getting anything!!!!
