Long slim neck LNB's are also handy as you can adjust the focal point better than a standard LNB.
Multi sat set up
ok sorted 28.2e on dish today before heavens opened. so now its just a matter of moving other lnbs about to get 19.2 and 13?Fave replies from various threads
yeah.. i know
.. but combination of stuff, made me sort 28.2e first. shouldnt make that much of a difference really should it?
I think you will lose 28e when you adjust the dish to get 19e, whereas if you had got 19e first its just a case of pivoting the arm and dish in order to get the rack on the correct slope to get the other satellites, but now when you adjust to get 19e the adjusting of the dish means 28e will disappear on you, so to me it was futile and not what anyone advised you to doComment
well its easy enough sorted, the main reason i went for 28.2e first after the shitter of a day i had yesterday, was to make sure i COULD, as its what the kids watch most, (i hardly watch tv). nothings been locked into place yet as i knew i had more fiddling to do..Fave replies from various threads
Day 3.. trying AGAIN to find 19.2 got satfinder set to 10744 / 22000 /h arte. my agc keeps fluctuating in the high 80's low 90's but snr stays at 0. same when i try to find 13.0e on the bloomberg transponder. I can get 28.2e fine now, which makes it all the more frustrating why it wont lock on to any other satsFave replies from various threads
AND for some reason... its just locked on.. maybe the wind blew it because i hadnt tightened everything up yet.. but its THERE
scanning now with 100% signal
Only one lnb is on track at the moment, so after this scan, how do i go about setting up the disecq?Fave replies from various threads
another update. while scanning on 19.2e, its picking up a load of 28.2e channels such as blighty which arent on 19.2e???Fave replies from various threads
make sure you only connect directly to each lnb in turn whilst setting up
then set the diseqc switch up as astra - 19 on 1 or A , hotbird - 13e on 2 or B , astra 2 - 28e on 3 or C , and leave 4 or D free in case you wish to add a 4th lnbComment
yeah i had
. im scanning on 19.2e definitely now arte digital in scan, bein sport max etc..
only at 43% snr but its lockedFave replies from various threads
i physically cant heighten the pole any more.. i may be able to heighten the dish on the pole an inch or 2.. and thanks to the dish arm, i cant alter that in any way. so im stuck with lnb skew, track skew and maybe dish heightening a bitFave replies from various threads
