Multi sat set up
  • digicon
    • 8261
    #16
    Long slim neck LNB's are also handy as you can adjust the focal point better than a standard LNB.
    • dick b
      • Jun 2009
      • 2462
      #17
      @ shady, pic of a setup I used for a while if it helps to show whats needed you just wont need the 16E lnb and substitute 28.2E for the 23.5E one
      • Shady
        Shite Link King
        • Dec 2010
        • 6404
        #18
        ok sorted 28.2e on dish today before heavens opened. so now its just a matter of moving other lnbs about to get 19.2 and 13?
        • ramjet
          • 2995
          #19
          normally you start with 19e and then sort out 13e and 28e afterwards, I am sure I mentioned this previously and you also mentioned it in post number 6
          • Shady
            Shite Link King
            • Dec 2010
            • 6404
            #20
            yeah.. i know .. but combination of stuff, made me sort 28.2e first. shouldnt make that much of a difference really should it?
            • ramjet
              • 2995
              #21
              I think you will lose 28e when you adjust the dish to get 19e, whereas if you had got 19e first its just a case of pivoting the arm and dish in order to get the rack on the correct slope to get the other satellites, but now when you adjust to get 19e the adjusting of the dish means 28e will disappear on you, so to me it was futile and not what anyone advised you to do
              • Shady
                Shite Link King
                • Dec 2010
                • 6404
                #22
                well its easy enough sorted, the main reason i went for 28.2e first after the shitter of a day i had yesterday, was to make sure i COULD, as its what the kids watch most, (i hardly watch tv). nothings been locked into place yet as i knew i had more fiddling to do..
                • Shady
                  Shite Link King
                  • Dec 2010
                  • 6404
                  #23
                  Day 3.. trying AGAIN to find 19.2 got satfinder set to 10744 / 22000 /h arte. my agc keeps fluctuating in the high 80's low 90's but snr stays at 0. same when i try to find 13.0e on the bloomberg transponder. I can get 28.2e fine now, which makes it all the more frustrating why it wont lock on to any other sats
                  • Shady
                    Shite Link King
                    • Dec 2010
                    • 6404
                    #24
                    AND for some reason... its just locked on.. maybe the wind blew it because i hadnt tightened everything up yet.. but its THERE scanning now with 100% signal .
                    Only one lnb is on track at the moment, so after this scan, how do i go about setting up the disecq?
                    • Shady
                      Shite Link King
                      • Dec 2010
                      • 6404
                      #25
                      another update. while scanning on 19.2e, its picking up a load of 28.2e channels such as blighty which arent on 19.2e???
                      • ramjet
                        • 2995
                        #26
                        make sure you only connect directly to each lnb in turn whilst setting up
                        then set the diseqc switch up as astra - 19 on 1 or A , hotbird - 13e on 2 or B , astra 2 - 28e on 3 or C , and leave 4 or D free in case you wish to add a 4th lnb
                        • ramjet
                          • 2995
                          #27
                          not possible, you must have locked on to 28e for that to happen
                          • Shady
                            Shite Link King
                            • Dec 2010
                            • 6404
                            #28
                            yeah i had . im scanning on 19.2e definitely now arte digital in scan, bein sport max etc..
                            only at 43% snr but its locked
                            • ramjet
                              • 2995
                              #29
                              ok, once that has scanned in , save it and dont bother trying for anything else yet
                              you need to try adjusting the dish , dish mount , lnb skew and in and out on the lnb neck until you improve that signal , to something like 70% to 90% from your 40%
                              • Shady
                                Shite Link King
                                • Dec 2010
                                • 6404
                                #30
                                i physically cant heighten the pole any more.. i may be able to heighten the dish on the pole an inch or 2.. and thanks to the dish arm, i cant alter that in any way. so im stuck with lnb skew, track skew and maybe dish heightening a bit
