Spiderbox 5000 rs232 recovery problems
  • ramjet
    • 2995
    #16
    Originally posted by yasminandrio
    Right I hope I'm using the right cable are null modem and cross over the same? The on what I have is female to female 9 pin
    there are 2 cable types , straight wired and crossover
    a crossover cable is a null modem cable and wired as follows
    pin 2 to pin 3
    pin 3 to pin 2
    pin 5 to pin 5
    there may be others wired or not as the case may be, but the important pins for this task are as above
    lnbf normally indicates a short circuit on the lnb or motor coaxial cable, but you say this isnt connected ? so cannot be a coaxial cable fault
    in which case maybe the box is faulty ? so maybe you would be better to just scrap it and buy the new 6000 HD box ?
    • yasminandrio
      • 1256
      #17
      I already have other boxes just wanted to sort this one out I might see about new cable thanks for all ur help.
      • yasminandrio
        • 1256
        #18
        Now I'm thinking its the cable I'm not 100% sure but I am thinking it's that, as I think I have a serial null modem cable which I believe is wrong! Would I be able to buy on in pc world or marlin?
        • ramjet
          • 2995
          #19
          yes they both sell them at very silly prices, although they will probably try and sell you the straight wired serial cable and not the null modem cable
          you can easily test your old cable with a multimeter according to the pinouts I gave, to see if it is a null modem cable or not
          • yasminandrio
            • 1256
            #20
            Wtf!, you lost me again! What is a multimeter I've googled it and I don't have one laying about the house!
            • ramjet
              • 2995
              #21
              read the wiki
              Multimeter - Wikipedia, the free encyclopedia
              • ramjet
                • 2995
                #22
                checked flea bay and cheap ones go for between ?3 and ?6 and null modem cables are also very cheap too
                you could probably buy a cheap multimeter for testing leads and a new null modem cable on there for less than m*pl*n`s price for the cable only
                • yasminandrio
                  • 1256
                  #23
                  Found cable on there delivered for ?2.56 just getting that, thanks again
