2 satelites, 1 dish
cant you just get yourself say a quality 85cm dish like the gibby or a orbital80/td78 if funds are tight and 3 bullet nose lnb,s/1 bullet nose for 16e and 2 normal for 13e/19.2e as this will give you 13/16/19.2 of 1 dish and still have a spare port for say 23.5 or 28.2. i know it will cost a little bit more but it will last many years and look better on your house than 2 seperate dishes ect. regards mdtDM800HDSE SIM 2.10. SSL84D OPEN-ATV ORBITAL 80CM/DARK MOTOR/IBU/53E-30WComment
Without knowing the exact channels note down the frequency's and check all against each other, as you have 4 Bands H/H,H/L,V/H,V/L if all the ones are gone in the same band then it could be an LNB fault
I think is the lnb faulty cus at the same time some frequencies have good quality and almost all others have 0 % qualityComment
I got a new LNB.All working fine.
Im thinking to make another upgrade.I have a separated dish(80cm) with a single LNB(13E)
Can i add 28E on that dish?Comment
