Forget the Amiko get a proper mispel based machine such as the TM nano if you want an E2 machine
Best easy to use box ?100-150??
The initial setup and learning how to use the box is time consuming, but once it's up and running and you know what you're doing, it's a doddle.
Channel lists update automatically with auto bouquets, epg downlaods at a scbeduled time, etc.
It is a bit of a learning curve, but so worth it.Comment
This is such a hard choice. A descent twin tuner seems to be about ?200 if I go for an enigma2 I believe which for the benefit it would give me is not worth doing.
A single tuner with enigma2 is around ?120, so the only descent upgrade I would gain from my F5 that I would use is the EPG.
I have buyer for the F5 giving me ?60 back, so is it worth for me to spend an extra ?60 just to get a descent EPG? Decisions decisions...Comment
Ok here is your questions do I want to have to upgrade my box once support stops for my closed source or more security measures are introduced if the answer is yes but closed source and you will get a good box for your money. If the answer is no then spend the extra for a good e2. Personally I would save a bit longer and spend 300 on solo 2. These boxes are so much more than just a Sat receiver you will also be able to use it as iptv with the correct plugin and that is just one of the hundreds of options available.Comment
100 quid Dreambox 800hd from China, can't fault them and tried and tested, Andy.New Members http://www.digital-kaos.co.uk/fo rums/f5/forum-rules-2/ A Good Place To Start
m8 here is a good option a vu uno clone and a genuine twintuner module fitted to it this can all be had for around 190 fitting the tuner module lets the box run as a genuine box and so far i cant fault the one i have
i also have clone duo's as well and they dont get a look in now to the twintuner unoComment
