ok all i am trying to install 10e...
  • youngie1
    • Sep 2009
    • 184
    ok i am getting a few 10e transponders but most of them are 9a sat why is this happening i am using spiderbox 9000hd software version ver f5.41 ldr ver 00.31 last update 29 2012 cheers all lee
  • cactikid
    • 12017
    have you double checked the sat you scanned on?
    • youngie1
      • Sep 2009
      • 184
      yes mate i have i am getting 10e satas plus 9a for some reason but only a few 10e cheers lee
        If your doing a blind scan then start the scan off at around 10700 to around 11700 and then strt again at 12500 this will avoid the overlap with picking up the TP's on 9.0? east
        • ramjet
          • 2995
          as they are only 1 degree apart you will get the overlap mentioned by digicon, so that is why you get both satellites, its like you hearing somebody knock on your next door neighbours door so you both look out the window !
          • youngie1
            • Sep 2009
            • 184
            thank you all what is the best lnb to increase signal on sats thanks lee
            • ramjet
              • 2995
              opinion varies but generally you cannot go wrong with the inverto ultra black lnb (the one I am using on my dish)
                I am afraid there is no miracle lnb that will give you more signal that would require a larger dish.
                A Inverto Black Ultra may help a little
                • youngie1
                  • Sep 2009
                  • 184
                  ok mate i have all the sats in apart from badr sat 26... not bothered there... i have 7w and 7.3w rigged in ok i get most channels apart from jsc witch is massive for football this season... i get them but keep losing signal... i am using a 90cm dish on them transponders. was thinking of buying a bigger dish 1.2 should be ok but will i lose my sats buy using the bigger dish and need someone to set it up again for me... or maybe i should try a new lnb to increase the signal... i idears here cheers lee
                  • ramjet
                    • 2995
                    you will probably need a much bigger dish than 1.2m for those jsc channels , maybe 1.8m to 2.4m , which require planning permission and polar mounts with actuators and a vbox or you will have to ground mount the pole and dish, 1 metre is the maximum dish size allowed on a property without permission as a permanent fixing
                    there are many threads about this on many forums, but going from an 90cm to a 1.1m or 1.2m dish is unlikely to solve all your problems although there is no substitute for having a larger dish
                    as for 26e, there should be no problem in you obtaining some of the fta channels on there, but again , size is an issue so the bigger the dish the better
                    • youngie1
                      • Sep 2009
                      • 184
                      ok mate thank you i am getting signal on both 7w and 7.3w signal 65% and quality 44% on all jsc and all the same on the rest ad sports qatar tv all working no problem just jsc... why is this mate as there are all on the same signal and quality.... cheers lee
                      • ramjet
                        • 2995
                        jsc is not aimed at the uk and we are outside its footprint, that is why (it is aimed at the middle east)
                        in other words, the uk is not the centre of the known universe
                        or do you mean "why are they scrambled ?"
                        • youngie1
                          • Sep 2009
                          • 184
                          thanks mate i am watching them now mate on my dish jsc all good for now... but i am thinking of changing my lnb for the one you said you use mate inverto ultra black lnb... and hope it helps the signal because my signal now is 67% and quality 46%... no freezing yet... so i need the quality to rise alittle more and that should be all good... just need to keep it stady at 46%... i have read up on the lnb and people are saying WOW what a big diffrence the inverto ultra black lnb has mad on there sats... cheers mate lee
                          • ramjet
                            • 2995
                            about the same as me but I am further north and west than you I believe, but also my dish is 1.1m with the twin ultra black lnb, so yes a bigger dish, or at least a better lnb like the ultra black or tm gold should improve it, depending on the time of day of course as you will find it varies according to the time of day (and yes they are subscription)
                            • youngie1
                              • Sep 2009
                              • 184
                              thats cool mate i live in the midlands... i think a better lnb should do it lets hope... there are all working at the moment cool... night time does seem better this end mate i think it should do it thou mate... have you tryed the tm gold mate cheers lee
