Ok pal I will try and get the latest bundle today after 9.00pm.
Vivabox 7000 hd channel list
Note:All information given is to be used for educational purposes only and should not be taken seriously. -
Please read instruction before installation.
This is for VB-7000HD
Like always I am not responsible for any damage to equipments of any kind.
1. Unzip both files and install both files separately in the USB.
2. You will have 2 options when asked for installation channel list or firmware.
3. Reboot after installation DONE.Tools owned: Hammer, Chisel, Crowbar, Punch, Chainsaw, Cutter and Brain!!!
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
Thank you very much my friend, I will check this.
OK, I will give you my experience with this box, which I find with a poor quality, and I would not recommend it for a new buyer, unfortunately:
- There is no website or official support
- The box does not let me do any search as it is
- When I upgraded (the first zip uploaded to this thread) and imported the channels list, it worked! But I had to use the 'Ebird1, Astra 2x' for my channels search, even though I am in the Nilesat position. It turns out that this is the only Sat I can search for, as it was uploaded in the channels imported.
- When I reset the factory settings, back to the starts. No 'Antenna Setup' enabled, cannot search for channels, coz no sat is loaded to 'Antenna Setup'
- When I upgraded the latest firmware uploaded by 'super jumbe', the screen blacked out. It turns out that the HDMI is not working. Had to use the AV output to downgrade to previous firmware, and import the old channels list to make it work again.
Now I am happy (pretty much) that it is working with (hopefully) all the channels in Nilesat even though I used Ebird for search.
The only thing I would appreciate to have, is a channels list from Nilessat (or ideally all satellites) so that I can import them to be able to search those satellites if needed. Not a great approach but seems to be the only option.
I also have to avoid resetting to factory settings.
Thank you in advance.Comment
Hi I am New Here But Just Wanted To know how to categorize channels from sat into asian,sports/ent etc. Thanks In AdvanceComment
I think the easiest way is to create Favorite groups. I think you can have more than 10 groups. So you can put each group fav group (Asian, sport etc..) and seek them when needed.
I wonder though if you are experiencing the same problems that I did, or maybe just my box is faulty?
Cheers.Comment
Try this should work To upload 'channel list', goto tools and choose upgrade only "Ch_list". nothing else or i am not taking the blame.
Read here first before you delete all.
Try here m8 hope it helps
VIVABOX ReceiverLast edited by WOODWARD395; 9 October, 2014, 21:31.Education is not the learning of facts, But the training of the mind to think
So hit the thanks button if I have enlightened you.Comment
Hola, ha llegado a mis manos este receptor Vivabox vb-7000 hd y la verdad no se cómo empezar.
Alguien que me pueda ayudar?
Gracias y un saludo.Comment
[QUOTE = hazletree; 2111627] Aquí tienes este es el firmware y la lista de canales espero que ayude
[/ QUOTE]
Cómo puedo bajarme este firmware?
Saludos.Comment
No se porqué no hay nadie que me impugne, <br> <br> <br> <br> <br> <br> <br> <br> <br> <br> Saludos.Comment
[/ QUOTE]
Por qué no me puedo bajar este firmware?
Saludos.Comment
Vivabox vb-7000 hd
[/ QUOTE]
Buenas, algún Moderador, Administrador del foro me puede ayudar a descargarme este firm.
Saludos.Comment
