Astra 2E to join 28.2e fleet...more channel chaos?
  • Hadron
    • Nov 2012
    • 2102
    Astra 2E (currently nearing 43.5e for testing) will be joining the fleet at 28.2e over the next few weeks. It will eventually replace Astra 1N, which will shift over to 19.2e.
    After just getting over the Astra/Eutelsat merry-go-round, expect more fun & games when mass channel changes occur again in a few weeks time!
    Astra 2E Satellite at 28.2? East, channels & frequencies
    Astra 2E can be tracked here:-
    LIVE REAL TIME SATELLITE TRACKING AND PREDICTIONS: ASTRA 2E
  • digicon
    • 8261
    I would not worry too much about this as the 2E was a planned change for 1N and possibly 2A due to its age and 1N moving to its original slot of 19.2? east.
    It will carry the same Transponders so should be pretty painless and an instant swap like for like the only difference should be the Power so signal quality should improve especially on the older 2A transponders.
    The Reason we had the Mass upset with Eutelsat losing to Astra was that Astra had to create new frequency's to accommodate there newly acquired channels.
    • Hadron
      • Nov 2012
      • 2102
      Well, it took rather longer than a few weeks, but 2E finally arrived at 28.2e today.
      SES?s ASTRA 2E SATELLITE GOES LIVE at 28.2/28.5 DEGREES EAST OVER EMEA - SES.com
      • digicon
        • 8261
        Transition of channels from 2A and 1N starting Today 1st Feb, Expect some upset especially in the Openbox Forum LoL :-)
        • mtv1
          The Stig PT
          • 4413
          thanks for the heads up ladies
          • P&D
            • May 2010
            • 2684
            Shit hitting the fan comes to mind ....the openbox forum will be red hot with question's ..god bless us all
            • Blitz101
              • Dec 2012
              • 12
              So when should all settle down again? Tomorrow evening? Or has mostnall freq already changed over now?
              • digicon
                • 8261
                The Transistion wont be done in a day the last one took a few weeks so expect something similar
                  I can not understand, when joining or separating fleet why does it upset channel frequencies is it because they add more channels or less channels??
                  • digicon
                    • 8261
                    Some may not change Main frequency but the SR could change slightly from a 27500 to 22000 etc.. one of the reasons for the long transfer i assume is to let $ly make sure there Official receivers are not disrupted and update without a hitch normally done during the Late evening Early morning.
                    • jacquesy90
                      • Dec 2013
                      • 92
                      Will we have to update our channel lists when these changes happen?
                      Im on a vu+ solo using catseyes settings with autobouquets running.
                      Or will autobouqets update it automatically. Cheers
                      Ste
                      Sent from my X506-3G using Tapatalk
                      • DigitalVandal
                        • Jan 2014
                        • 138
                        This doesn't make sense to me. I've only been looking into the openbox/Enigma boxes for a little over 3 months, yet although I was worried about flashing the box and changing channel lists at 1st, I've become reasonably proficient with it because of reading all of your extremely informative posts. All it takes is a bit of time and common sense and away you go.
                        • southpaw
                          • 2233
                          Unfortunately common sense and openbox section don't usually go together mate
                          • mtv1
                            The Stig PT
                            • 4413
                            links dead in original post
                            Eutelsat 28A & Astra 1N/2A/2F at 28.2?E - LyngSat
                            • benny/9
                              • 1964
                              this has been on other forums for days about it
                              January 31, 2014 08.53 Europe/London By Robert Briel
                              The Astra 2E satellite will enter into commercial service
                              in the orbital arc of 28.2/28.5 degrees East on February 1, 2014, its tightly focused beam causing consternation to British ex-pats in Spain. Over the coming weeks, BSkyB, Channel4, ITV and BBC programming will be
                              transitioned to the new satellite with its powerful footprint over the British Isles. Newspapers serving the British community in Spain are referring to the Great British Switch-off as residents worry about losing reception of the channels from the country they left behind.The satellite was launched on board an ILS Proton launch vehicle from the Baikonur Cosmodrome in Kazakhstan on September 30, 2013.Extensive in-orbit tests have since then confirmed the satellite to be fully operational and performing to specifications. Astra 2E has now been deployed at its final destination in the orbital arc of 28.2/28.5 degrees East, where it is co-positioned with Astra 2A, Astra 2F and Astra 1N. The satellite was built for SES by Astrium of France. Based on the highly reliable Eurostar E3000 platform, the spacecraft carries 60 Ku-band transponders, including 12 incremental transponders for delivery of services outside Europe, as well as 4 Ka-band transponders.Astra 2E enables the delivery of next generation broadcast and broadband services in Europe, the Middle East and Africa. Astra 2E, which had a launch mass of 6 tonnes, features a wingspan of 40m after its solar arrays have been deployed in orbit, and is designed to generate 13 kW of spacecraft power up to the end of its 15-year design lifetime.
                              Please Read Carefully!
