Need Some Help Choosing a Box.
This topic is closed.
I suppose you need the box were you can spend more time on box say no more starview you can not beatHi all, currently I have a Skybox F3S and while I am happy with the quality the EPG is driving me crazy. I'm currently spending countless Minutes/hours flicking channels to find something to watch hence the reason I'm asking for much needed help/advice.
I have been scouring countless forums trying to find the box I need and have been left somewhat, bewildered.
So basically I have came to the conclusion that:
I need a box that has Auto Bouquets - So I dont have to mess around when channels/transponers change.
Need at Least 7 Day EPG
Accepts CCcam
And finally and option to record (Internal/External) Not fussed
My Budget would be around ?150-?200
If someone who's knowledge exceeds mine could possible point me in the correct direction I would be very gratefull.
Many Thanks
Note:All information given is to be used for educational purposes only and should not be taken seriously.Comment
I have a Skybox F5 - Isn't the Scrambled message a ................., "The Thing We Can't Talk About" , with it being overloaded etc ?I bought the solo 2 about a month ago....wish i would of bought it 12 months ago
they are great boxes....i can tell you one thing bye bye to the old messages from the F boxes you get ....no signal...scrambled....freezing picture.......
once you set the box up these will be things of the past....
ok, So the box has arrived today! All seems good so far although I am having a few issues.
I loaded VIX 3.0 onto the box ok & ripped apart my old Western Digital My Book for the 1TB HDD and installed that ok.
Basically I am having problems setting up the tuners. I am using 2 tuners but I think I am only setting up 1. To that end how should I set these up as Im obviously making a balls up somewhere along the line?
Also, The VIX menu needs calibrated and I cannot find this option anywhere - By this I mean I cannot see the full menu as if its too big for the screen? The resolution is correct?
ThanksComment
tuner config tuner a 28.2-----settings-simple----mode-single----sat-28.2-------send diseqc-no---------tuner b-----settings-simple----mode-single---sat-28.2---send diseqc-no.
check tv not on overscan blowing up picture?
sometimes you might have to adjust picture in system settings---user interface-position setup.Comment
Worked a treat. Found the setting I was looking for its under OSD.tuner config tuner a 28.2-----settings-simple----mode-single----sat-28.2-------send diseqc-no---------tuner b-----settings-simple----mode-single---sat-28.2---send diseqc-no.
Box is working amazing. I have Sgt Flip Flops Bouquet and EPG setup.
Any other add ons that would be recommeded?
Happy Man :-)Comment
Never mind, found a few...Tsmedia & XBMC add-ons! Now I can sell my Apple TV 2 & invest in a Motorised dish as these addons have everything I need! The more I play around with the box the more im loving it. Also after alot of researching I've done away with CCcam & installed MGcamd and what a differance it makes .................
I want another one for the bedroom now.
plugins
autobouquets - autotimer - tsmedia - ondemand - 1channel - icefilms - crossepg - cooltv epg addon -
just look through the dreambox and vu forums here for advice and help and suggestions - like catseye E2 lists instead of flipflopsLast edited by ramjet; 24 October, 2013, 09:48.Comment
I need a question answered and have looked everywhere for the answer, I'm not sure if the question will break the rules but if it does then I apologise in advance and admins please delete.
You are Correct it breaks the Rules
As I said I've looked for sometime for the answer but have come up with nothing.
ThanksComment
