how to install a motorised dish
hi mate i have i m dish motorised and openbox s9 hd and i get tring for footy sky italia aljazeria hotbird i get them all mateComment
Your box will supply the power when connected to the motor through the satellite cable.Comment
Thank you vorlon
the reason that i asked is that my sky 60cm quad dish moved in the heavy january winds and it has moved my dish slightly and now i have lost some of my chanels on my BLADE COMBO but i can scan other satalites like
26.0E BADR 34
23.5E ASTRA 1D3A
19.2E ASTRA 1
13.0E HOTBIRD
4.8E SIRIUS 2/3
and i can get my sky sports chanels that i lost from 28.2E ASTRA/Eurobird
that glitch and freezed but not all the chanels that i lost
i can not get up to put the sat dish right because i can not climb laders but i have found a sat instaler in South Sheilds that will fit a 80cm motorised dish for ?160
my dish is on my front south facing wall but my blade is at the back of the house but i have a free sat in the front room so if i get the sat installer to fit the dish in the front room
would i be able to extend my lead from the sky dish to the motorised dish with a extension cable or would the connecter upset the signal as i do not want to re rout my sat cable as it goes through the fromt bedroom wall, along the top landing, down the staircase -- along a long passage way then in to my back room - i used top quality cable when i first set it up
sorry for the long winded question but i wanted to be as exact as i could
Thanks in AdvanceComment
As your 60cm Sky Dish is of out of alignment there would be no point in doing what you want to do.
You would be better asking (nicely) the installer if he would realign the 60cm for you and using that for freesat.
Your new 80cm dish should pick up a hell of alot more channels once installed.Comment
Found your motorised set up guide very helpful My satellite system - Humax 5400, STAB motor H100, 1m dish was set up quite a few years back. I get most satellites, those in the East and Hispatsat in West, also Thor at 1w. The motor is set at 54N lat and the dish elevation is 24 degrees. I noticed howvere that I can't get Atlantic Bird 3 at 5w which would be due south and at top of arc for my long (-5.6E). Should the dish elevation be at 22 degrees which I read from dish pointer for motorised systems. I was going to try and adjust it myself. Thanks for any info.Comment
once dish elevation is correctly set for any sat it will be right for all the others the scales on dishes are not very accurate.if you are getting some satellites ok you should if on USALS get the rest,line of sight and proper alignment being ok.
If you are using Diseqc 1.2 you may not just be hitting the location, try nudging the dish L/R with the boxes motor controls.
11.591 V 20000 has some good strong french channels on it France 0/2/3/5.
It may be worth considering a full refit if its been up a long timeComment
Thanks again for your tip. I discovered in fact that the channels I was using, downloaded from another website as part of motor settings for humax and identified as 5W channels, were not 5w channels. The France 2 coordinates provdied a strong signal on 5w (quality 90%) so I don't have to change anything. Hope this helps somebody else who may be trying to find a satellite with the wrong channels. Regardsonce dish elevation is correctly set for any sat it will be right for all the others the scales on dishes are not very accurate.if you are getting some satellites ok you should if on USALS get the rest,line of sight and proper alignment being ok.
glad your sorted but just to let you know several satellites have had name change and the old Atlantic Bird 3 is now Eutelsat 5 West AThanks again for your tip. I discovered in fact that the channels I was using, downloaded from another website as part of motor settings for humax and identified as 5W channels, were not 5w channels. The France 2 coordinates provdied a strong signal on 5w (quality 90%) so I don't have to change anything. Hope this helps somebody else who may be trying to find a satellite with the wrong channels. Regards
Good guide.
Had my technomate 2300 setup for more than 2 years, never needed anything but, 28 and 13e. Tried to scan 4.8e and nothing.
I've allighned to thor nicely, i can find 13e and 19 e and 28e, but not 4.5 e.
Using usuals.
thanks.
PS. had same dish, just fixed set up on 4.8 e before, so there is nothing on its way.Comment
