hi m8, please do you know of any motorise dish technician ? i've got everything installed before but cause i moved adress, so i just need the tech guy to fix the dish up at my new adress. cheers in advance
when i fit the pivot bracket to the dish mount i presume that i set it Vertical to the dish mount, and i do not set it to the Latitude markings on the pivot bracket - then only set the latitude on the motor am i correct, it is a Gibertini 85L and a Dark Motor Supreme sorry for sounding Thick, but as i see it if i set the latitude to the pivot bracket then set it again on the motor it will be miles out of line as i presume the pivot bracket markings are for a fixed dish
Thanks in advance
Thanks in advance
but are the channels scrambled so you have to pay for them or do you pick them up for free.thanks
