What is Sky's high definition resolution broadcast standard in Ireland, I was thinking about subscribing to this service but could not get a specific answer from the customer rep, is it full 1080P or 1080i your comments are appreciated thanks.
Sky HD Resolution Ireland
Sky and Virgin both transmit in 720p (1080i). They will not be transmitting in 1080p for many years to come because the cost is prohibitive and they don't have the bandwidth
Only 1080p Blu Ray is 'true' HD.. some Blu Rays are 720p though and some are 1080p.. I'll give you ?1m if you can spot the difference.. Why..? because its less than 1 frame per secondLast edited by opsmonkey; 27 July, 2009, 00:58.
From Sky website..
which is why i had 720p then 1080i in brackets as both formats are supported..# What format will Sky+HD broadcast in?
The highest high definition broadcast format in the UK is 1080i, with Sky+HD supporting both this and the 720p HD format.
Either way it doesnt really matter as all the OP needs to know is HD programs aren't broadcast in 1080pLast edited by opsmonkey; 27 July, 2009, 03:43.
The broadcast is transmitted in 1080i. 720p is supported because the box can take that 1080i broadcast and scale it down to 720p if your tv can't handle 1080i. OP asked about broadcast resolution, technically any resolution is supported if you have some kind of scaler in your box, or another box, or your tv scales
