Hi all last few weeks had a problem with recordings on playback they glitch and pixelate yet the channel they are recorded off is fine as have watched the channel whilst recording if I rewind then play again the recording is ok where it previously glitches have re-installed vix image the same no change have also had every now and again colours flashing across the screen not very often and had to re-boot to get rid of it tried recording on each tuner but still the same. have now suspected the box may be overheating so placed a laptop fan under it tonight so will see how it goes.was wondering if anyone has had any similar problems.
. It may be errors within the image or it could just be the heat. How do you have it set up m8. I mean where are you storing epg, picons and file swap. If you are keeping them on hdd it will be running constantly generating a lot of heat. I have usb plugged in to store all the above and for timeshift. I'm also using a wd Green hdd which only spins up to record (not timeshift) all in a vain attempt to keep the heat down. If the missus starts her nonsense recording 3 things and watching something else the bloody things runs at around 53? way to hot for my liking but with no fan not a lot I can do about it. I don't have any recording issues even at that temp though
