what size dish
  • gibbo74
    • 445
    what size dish
    can any body tell me what size dish is needed for thor 1w in the manchester area ?
    if fitted a 80cm for a pal today and i can get astra 19.2 28.2 hotbird and lots more but for some reason the dish will not pick up thor not even a little bit
    ive got a horizan sat metre all signals are ok for most thinks
    so is it the size of dish
    by the way he supplied is own dish i would have sold him a 90cm
  • .: JaCkPoT :.
    Retired Sat TV Addict
    • 5607
    the install might be ever so slighly out, send the motor to 1west and fiddle with the elevation without loosening the bolts....
    ___________________
    In the good old days, I had
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Maxx 110cm Dish
    Technomate 2300 Motors
    • gibbo74
      • 445
      can any body confirm what size of dish i need to get thor in the manchester area ,been trying with 80cm and cant get a think
      • portbhoy
        • 717
        Ideally a 1m dish for a good signal but you should still get something on an 80cm Atlantic Ocean - LyngSat Maps
        • gibbo74
          • 445
          not getting anything and im using an horzian sat metre all other sats are ok just thor
          • benny/9
            • 1964
            you should get some of the stronger tp's like bbc world news etc:
            with a 80cm dish but to get all tp's in all weather conditions
            i would use a 1mtr dish i'm about 7 miles south of you i use a 1.2mtr dish
            Please Read Carefully!
            • gibbo74
              • 445
              i can get it at home no problem with a 90cm dish,
              but im using a tm500 and when i try to save the lon ang lat it wont save ,also when i drive the dish to zero it ends up at 10 degree east
              • portbhoy
                • 717
                Gordon Bennet I'm tripping over SD peeps wherever I go today
                • satsid
                  • Aug 2009
                  • 815
                  Hi m8 im in north west,meter dish will do,but in rain you might lose signel if bad.Best bet if you can go this,is a 1.2 meter dish.With this size you do good on satellite feeds as well
                  • terriers
                    • 580
                    1.2m for 1west!! your having a laugh....
                    90cm plenty big enough if set up properly with a good low threshold lnb....also 16e fine too...
                    • satsid
                      • Aug 2009
                      • 815
                      No ofence m8 been around long enough to know footprints.Iv a wave dish thats a meter in north west,its just enough for 1 west digi tv.I was chatting on rain & fade out,you can lose the signel.With a 1.2 dish you wont.Now im having a laugh @ you on rain.
                      • terriers
                        • 580
                        your dish is set up wrong m8...only just getting it on 1m...
                        i presume by that you fitted it yourself....
                        90cm fine even with rain fade...get back up them ladders m8 and finish the job off....
                        • satsid
                          • Aug 2009
                          • 815
                          Only been messing with satellite 20 years m8.My dish is fine & iv more than one dish.If ladders are needed sort your own out,mine are fine thanks.Reckon you read lyngsat by footprint,there reports are from good wether only,now dont be a turkey,as i will wipe the floor with you on this.
                          • terriers
                            • 580
                            Will you m8..you a sat engineer too??
                            i talk from experience..i,m not going any further with you on this
                            if you are only just getting it were you are on 1m,its installed incorrect!! period
                            I used to work in the north west 2-3 days a week and have installed hundreds
                            of dishes in your area and thor comes in loud and proud on a correctly installed
                            90cm dish...
                            • satsid
                              • Aug 2009
                              • 815
                              90cm dish...
                              That depends what part your in,im a bit more north than most.Ok if your on winter hill your get more signel but if sea level your get less.To be honest i dont care what youve installed,i know mine are bang on for signel.After 20 years from alog days i know my signels.I use a satlook meter,by the way thats better than what you have in other thread .
