hi there I have a vu+ duo I no the transponder has changed for the movies I have done a scan but not got them back any one help with this please thanks
did you run a new full scan as that should pick them up or others use autobouquets maker to run a new scan and refresh your bouquets.set your scan to run on sd as hd not viewable on 28.2.
I download another up to date XML file and put it the box, because it is faster than a full scan.
